DonParker Community Member
Posted: Wed Dec 09, 2009 10:32 am Post subject: |
I hope all my pics dont turn out
this bad.It looks good in person
but once I get it on the web it
looks like Ive been pounding
nails with it!! |
Posted: Wed Dec 09, 2009 11:37 am Post subject: |
I can't comment on the Binding post as I don't really know for sure, perhaps Rich can enlighten us all, but the Weaver Knob ( or Screw if you prefer) was used to fix/hold the Shroud cover over the gun's cylinder drum on the hero , you can see the screw and where it connects to, on the frame - hope that helps , (( nice idea about the sight rod though, you'd definitely need some method to adjust it - I'm currently working on a real working laser diode and driver board that I hope to fit into the sight rod !!)) |
Posted: Mon Dec 14, 2009 4:42 pm Post subject: |
Here are a few more pics. My sight rod is different
as well as the mounting system.
Don |
Posted: Tue Dec 15, 2009 7:31 am Post subject: |
Looking very good from the pics (a little dark sometimes...maybe the blueing of the metal)? I'm very impatient to see more pics as the work progresses  |
neosporing Community Member
Posted: Tue Dec 15, 2009 7:53 am Post subject: |
incredible build.
can't wait to see whats next! |
Posted: Tue Dec 15, 2009 9:44 am Post subject: |
^^Totally agree.
Insane build. |
Posted: Tue Dec 15, 2009 10:06 am Post subject: |
Is that anodized black, or something else? Looks great. |
Posted: Tue Dec 15, 2009 10:52 am Post subject: |
Thanks for the replies fellas.I know the pics are
dark but I just cant get the lighting proper.The
finish Im using is called Aluminum Black by
Birchwood Casey.When I first put it on it didnt
seem like it was doing anything but the more I
rubbed it the blacker it got.The stuff does give
the gun a blued look that I wanted though.
Ill tackle the outer grip frame and butt plate
next and post pics when theyre done.
Don |
Posted: Wed Dec 16, 2009 3:29 pm Post subject: |
Another pic.
Posted: Thu Dec 17, 2009 8:07 am Post subject: |
phenomonally clean and crisp lines!
you're machining is making the cast parts feel bad about themselves.
so you're 'staining' the aluminum? thats amazing, i thought the previous pics were painted.
so will the bolt eventually become functional? |
Posted: Thu Dec 17, 2009 10:58 am Post subject: |
Thanks Neosporing.Yes the bolt should work....hopefully.
Im working on the reciever now.Its a pretty complicated
piece as you know so Im kind of winging it.The Steyr
is the part Ive been holding off on because im not
sure if Ive got all the tooling to do it.Guess Ill find
out.
Don |
Posted: Thu Dec 17, 2009 12:50 pm Post subject: |
i just noticed the buttplate as well? if it's machined, can we see more of it?
..perhaps with the grips taped on  |
Posted: Fri Dec 18, 2009 7:09 am Post subject: |
Well Don, I gotta tell you; this stuff is rockin' I like the sight rod, very Han Solo blaster in its concept. Keep up the good work and good luck for the Steyr component of the build. |
Posted: Fri Dec 18, 2009 9:06 am Post subject: |
Truly exceptional work. you nailed the buttplate.
it's exciting to see the styer 'magwell' taking shape!
Posted: Fri Dec 18, 2009 9:21 am Post subject: |
If anyone is interested I could probably
do a run of butt plates. I only have my
offworld for the hole to hole dimesions
but Im sure others could give me the
needed dimensions for theirs as well.
Just a thought.
Don |
punctated Community Member
Posted: Fri Dec 18, 2009 11:14 am Post subject: |
Yes I would be interested in a buttplate for the OffWorld. I have a pewter one but would rather have it made from aluminum. I would also be interested in a barrel for the OffWorld blaster. |
Posted: Fri Dec 18, 2009 12:11 pm Post subject: |
I second the need for a Buttplate for the Offworld.
Posted: Fri Dec 18, 2009 12:31 pm Post subject: |
I would be definiteley be interested in two Offworld Butt plates. Maybe a third depending on price.
Awesome work |
