neosporing Community Member
Posted: Wed Jan 13, 2010 7:05 pm Post subject: Paypal sent. good luck! |
Thanks you so much for doing these!
good luck with the gig!
we'll be looking forward to your return!
neosporing |
ironfist Community Member
Posted: Wed Jan 13, 2010 7:05 pm Post subject: |
Your work is worth the wait.
Just let me know when you got'em and Ill paypal ya. _________________ The other Karl! |
mspaw Community Member
Posted: Wed Jan 13, 2010 7:29 pm Post subject: Machined Replacement Barrel |
Thanks for the support guys, I aim to please.
-Michael |
Posted: Thu Jan 14, 2010 1:10 am Post subject: |
what is your paypal address? |
tain669 Community Member
Posted: Fri Jan 15, 2010 11:01 pm Post subject: |
Could you please put me down on the list for the next batch and will you be making other BR blaster parts in the near future? Thanks. |
Posted: Mon Jan 18, 2010 10:43 am Post subject: |
Just want to make sure you have me down for a 'second-run' barrel, and say hello to Prince Willy as well - I understand he's in NZ even as we speak.
Thanks,
Barry |
Posted: Mon Jan 18, 2010 3:22 pm Post subject: |
I trust that mine is on the way? |
megagreg Community Member
Posted: Tue Jan 19, 2010 8:20 pm Post subject: |
I received my batch #2 Barrel today. It's great, awesome, can't say enough good things about it. Great work mspaw! |
Posted: Sun Jan 24, 2010 12:26 pm Post subject: |
Still waiting.......... |
Posted: Mon Jan 25, 2010 5:50 pm Post subject: machined barrel |
Clutch-
Its being sent today so sorry for the delay. Working from half a world away is a bit rough. But you should see it in a few days.
All the best!
-Michael |
Posted: Tue Jan 26, 2010 9:45 am Post subject: |
Thanks for the update! |
Posted: Sat Feb 06, 2010 2:11 pm Post subject: |
were the completed barrels in the 2nd batch all sent?
just curious, i know you are accross the pacific... i had seen that clutches was sent and was wondering if the rest were.
thanks.
neo |
Posted: Sat Feb 06, 2010 4:12 pm Post subject: |
Haven't received mine. |
Posted: Tue Feb 09, 2010 1:10 pm Post subject: |
i've received mine but the dimensions for the taper on the barrel seems to have been reversed...
it's beautiful though i know you are in the southern hemisphere, and i'm in no rush.
Posted: Tue Feb 09, 2010 3:54 pm Post subject: |
Got mine yesterday. I'm wondering the same thing. I'm also wondering why the post doesn't have the 'U' shape cut out in top so that it rests flush with the barrel? |
Posted: Tue Feb 09, 2010 5:32 pm Post subject: |
The World COn discovery showed that there is no U shape to it and that it is just a flat post.
So this is the correct version based on the real prop. |
Posted: Tue Feb 09, 2010 6:57 pm Post subject: |
I was hoping it would be something like that. Thanks for the info! I've felt so intimidated by this build ever since the worldcon discovery. Now, are our barrels incorrect as far as taper at the end? Mine is almost as flat as sid's. I can take a pic of mine if you want.
Also, how are you guys attaching the barrel to the gun frame? My sidkit has a small screw in the 'plug' that fits into the frame. The new barrel has no hole there. |
Posted: Wed Feb 10, 2010 2:29 pm Post subject: |
the cast allen screw will have to be counter bored or milled out. Same with the magazine housing to allow the mspaw screw to fit like the 08 version. Also, the revolver frame needs to be filed down a bit as the taped holes don't line up exactly. i'm hoping that because of the taper issue, mspaw might be able to make the minor adjustments to fit the 06 model. But the adjustments required to make the worldcon barrel fit the 06 model will only make it look better!
don parker machined out a gorgeous bolt for the 06 kit. Here are some of the early pics, as the 06 sidkit is still in the test fitting stage.
http://propsummit.com/viewtopic.php?p=31584#31584
Posted: Wed Feb 10, 2010 11:19 pm Post subject: |
Wrong thread for this Neo. This is MSpaw's thread for the barrel.
Posted: Mon Jul 12, 2010 7:46 am Post subject: barrel bevel |
any news on the reversed taper? |
