Posted: Tue Mar 02, 2010 9:20 am Post subject: |
| ItalianNinja86 wrote: | hey Rich one more thing i didnt see in your instructions is was size drill and tap to use for the butt plate
Thanks..Butt plate is: Plate its self, #30 all the way though, #12 for the counter sink, and # 43 drill and 4/40 tap for the main frame..
and what size drill an tap to use for the screw that goes into the back of the grip frame
Frame its self, #30 all the way though, #12 for the counter sink, and # 43 drill and 4/40 tap for the sub frame.
E-Wan Community Member
Joined: 07 Dec 2009 Posts: 22 Location: Los Angeles, CA
ironfist Community Member
Posted: Fri Mar 05, 2010 6:50 am Post subject: |
That hole is on/in the real 44 or 38 hand gun handel. Both guns use the same handle frame. Nothing goes in it on the real one either? _________________ The other Karl! |
Posted: Fri Mar 05, 2010 7:24 am Post subject: |
The hole is for a pin on a real bulldog to help hold the grips, it is not used on the prop for anything, but as it can be made out I of course included it as I did the big hole in the outer grip frame and there is suppost to be a smaller hole in the subframe as well, all unused...
If you really look close at the real grips it looks like they did drill holes for the use of a pin and perhaps found out like I did , the real pin was not wide enough to reach the new grips. Seems they did not make a longer pin and just left the hole in the frame and the holes in the grips.
I will have to take some more pictures...
ItalianNinja86 Community Member
Posted: Fri Mar 05, 2010 9:54 am Post subject: |
| Another question rich What drill bits are used for the holes in the sub frame (the bulldog's grip) |
Posted: Fri Mar 05, 2010 10:12 am Post subject: |
Best match to the hole.
Posted: Mon Mar 08, 2010 10:10 pm Post subject: |
Are we talking about the same hole? The one drilled with the #43 in this pic? http://s922.photobucket.com/albums/ad67/racprops/Propsummit%20SE%20Blade%20Runner%20kit%20instructions/Grips/?action=view¤t=045.jpg
| racprops wrote: | The hole is for a pin on a real bulldog to help hold the grips, it is not used on the prop for anything, but as it can be made out I of course included it as I did the big hole in the outer grip frame and there is suppost to be a smaller hole in the subframe as well, all unused...
Posted: Mon Mar 08, 2010 10:23 pm Post subject: |
Ok I think I understand the question better.
I thought you were asking about the hole in the sub frame or inner bulldog frame that is faceing us in the picture.
I now think you're asking about the hole in the outer frame after you have drilled it with the #43 Drill, I do both frames at the same time with the other two screws already drilled and tapped and both in place and tighten some, then I drill both frames with the #43 and once taken part again I then drill out the hole in the outer frame with a #30 and counter sink with a #12.
This then allows you to tighten the screw pulling the two frames tighter together and thus make them more sucured.
I reloaded the pisture with more detail.
The grip holding holes in the outer frame are both #43, then taped with the 4/40.
Remember get taping oil for the deep holes and go in say about couple of turns and then back up a turn and then go in a couple more turns and back up one or two turns and then back all the way out and clean the tap.
The chips can jam your tap and then break it off inside...
So go slow and remove it often and clean it and oil it will get the job done.
It the efford to turn the tap get aeven a little harder, remove it adn clean it and oil it..
jameth Community Member
Posted: Fri Mar 12, 2010 11:56 am Post subject: |
Rich,
Do both triggers work?? |
Posted: Fri Mar 12, 2010 12:02 pm Post subject: |
No the front one is a dummy as it was on the real prop.
I have cut it so if you misstakenly pull it, it should not cause damage.
Posted: Tue Mar 16, 2010 7:21 pm Post subject: |
OK Latest UPDATE::
I am hard at work on the next batch.
So those that are in the second batch please confirm and stand by.
We are a week to a couple of weeks to shipping.
Please have your tickets ready.
Posted: Wed Mar 17, 2010 5:38 am Post subject: |
and PLEASE! remember to PM me to let me know when you have paid and when you have received your kit so I may update the first post. Thank you. _________________ The other Karl! |
Posted: Fri Mar 19, 2010 1:54 pm Post subject: |
Does this include those who ordered the deluxe kit????
Are you wanting us to start paying???? |
Posted: Fri Mar 19, 2010 2:23 pm Post subject: |
Yes I am doing them now.
Castings all done, I am drilling and taping currently and will be fitting and sanding them.
Posted: Sun Mar 21, 2010 10:36 pm Post subject: |
Rich,
The guy who bought Paul's last uncracked bottle has a blaster of yours. He posted pics of it with the bottle over on RPF.
How does this current model compare to that one??????
Seen here
http://www.therpf.com/showthread.php?t=81890 |
Posted: Mon Mar 22, 2010 5:09 am Post subject: |
| I'm sure Rich will reply, but I do know he's fairly busy right now, so to answer your question , Rich has almost completely reworked the gun since his last release , all the little wrinkles and features discovered since the last main release have been incorporated into the Propsummit release making it the most definitive release to date , Rich took the oportunity in producing the Propsummit Limited Edition to completely re-work all the molds and to rectify all the things he's wanted to but didn't have time to do before , It now matches the hero closer that ever before and if I know the work that some of the guys can produced here ,it'll be completely indistinguishable from the real hero prop. I've just finished a Sidkit build (No:38 ) which was an early 2006 model and I've worked about 6 weeks on it to 'Worldconise' it , but comparing the two is like 'chalk and cheese ' the Sidkit is good , but the Propsummit is better and yes I know I have a vested interest, being Rich's UK importer ,but I'm saying this as a 30 year veteran model prop builder and restorer . |
Posted: Mon Mar 22, 2010 5:45 am Post subject: |
Glad to see you back John!
You still owe some replies!  |
Posted: Mon Mar 22, 2010 7:52 am Post subject: |
What he said....
If you reread this thread: I have posted pictures and offered details of all the changes and improvements in many posts.
Between all of your support, and the latest pictures of the Blaster at the last auction, I was inspirded to make all these corrections.
Of course all models will be of the new version, propsummit just got them FIRST.
I have added the words (?) 2010 V to the new plaque for this new model.
And I will work with people whom got the older version to upgrade them.
| propsjonnyb wrote: | | I'm sure Rich will reply, but I do know he's fairly busy right now, so to answer your question , Rich has almost completely reworked the gun since his last release , all the little wrinkles and features discovered since the last main release have been incorporated into the Propsummit release making it the most definitive release to date , Rich took the oportunity in producing the Propsummit Limited Edition to completely re-work all the molds and to rectify all the things he's wanted to but didn't have time to do before , It now matches the hero closer that ever before and if I know the work that some of the guys can produced here ,it'll be completely indistinguishable from the real hero prop. I've just finished a Sidkit build (No:38 ) which was an early 2006 model and I've worked about 6 weeks on it to 'Worldconise' it , but comparing the two is like 'chalk and cheese ' the Sidkit is good , but the Propsummit is better and yes I know I have a vested interest, being Rich's UK importer ,but I'm saying this as a 30 year veteran model prop builder and restorer . |
Posted: Mon Mar 22, 2010 2:14 pm Post subject: |
SSWWEEEEEEEEEEEETTTTTTTTTTT
The one over on RPF with the bottle. Did you put the finish on that one Rich??? |
Posted: Mon Mar 22, 2010 2:23 pm Post subject: |
I am not sure, I have only let a couple of good friends get unfinished models and a couple have refinished a finished model I sold them.
So I would ask him.
