TM Community Member
Posted: Thu Jul 22, 2010 7:33 pm Post subject: |
For those interested in the structural and seismic strength of the Textile Block system there is an interesting technical study titled “The textile block system: seismic analysis and upgrading” by A. P. Vargas & G. G. Schierle of the USC School of Architecture, Los Angeles, CA, USA. It was published in: Structural Studies, Repairs and Maintenance of Heritage Architecture X 645; WIT Transactions on The Built Environment, Vol 95, © 2007 WIT Press; www.witpress.com, ISSN 1743-3509 (on-line)
This rather short report can be downloaded for free at the above URL, but you do have to register to do so. I did, and excerpted the following:
“The textile block system is a unique structural system created by Frank Lloyd Wright in the early 1920s, before any seismic regulations existed in California. The first four houses, all located in California, have been deteriorating severely due to seismic and environmental effects.”
“This paper aims to analyze and upgrade with an affordable and non destructive method the Freeman House, designed by Frank Lloyd Wright in 1924, as a case study for testing the textile block structural system, and compare that system with those used in three other textile block system houses, the Millard, Storer and Ennis-Brown Houses.”
“There are three basic assumptions in the analysis of the original Freeman House. Firstly, it is assumed that the walls act as ordinary reinforced masonry, according to the IBC 2003. This masonry is weak in shear walls.”
“The walls are 8" thick, with one inch of hollow space. Therefore, for calculation purposes, they are assumed to be 7" thick. The original rebars are ineffective as reinforcement for the structure.”
Luckily, those at this forum who are interested in duplicating these tiles do so for use as a decorative appliqué. So the structural defects are only of academic interest.
Tony _________________ If only you could see what I've seen with your eyes. . . |
Posted: Fri Jul 23, 2010 6:42 am Post subject: |
Thanks Tony...read the report a few months ago. Interesting paper to be sure. Some experts are still discussing the woven structures of these series of "Block Houses" built by FLLW and the wear and tear they incurred during the various earthquakes (also the pollution hasn't help the quality of the cement and the blocks are showing deterioration because of it) and the fact that a lot of professionals engineers always doubted FLLW's calculation in terms of load, structural forces, etc. (see the report they did on Falling Water and the recent repairs done on the cantilever balcony). Just a word for the people here trying to do an entire wall with those tile: you'll have to ire an expert to see if your interior wall (depending on the size of course) is made to bear the additional load (if you choose to make these tiles out of a heavy material...plaster for example) I have a 16x16 inches plaster tile and its weight is about 5 pounds. |
Posted: Fri Jul 23, 2010 11:02 am Post subject: |
couple of tiles for sale on the rpf right now. |
Art Deckard Community Member
Posted: Sun Feb 13, 2011 10:53 am Post subject: |
This original prop tile, sold by Screenused.com a few years back, seems to be the opposite configuration to the ones in Deckards apartment.
Was it made up for the film but then never used, perhaps?
Is the photo flipped? (can't see why)
From the blurb:
When filming was completed and the set was torn down, all of the panels were to be destroyed, but a few were rescued by crew member such as this one. We have yet to see another panel (though we understand there is at least one other in another collection) - please let us know if you are aware of another. |
Posted: Sun Feb 13, 2011 5:28 pm Post subject: |
Wrong tile: the deep groove at the right hand side of this tile should be at the top. Beware: not a screen used tile There's enough pics out-there from the movie for people to see clearly the design used in Deck's apt. People from the production took plaster molds of the real deal: Ennis house in L.A. and made either vac-formed or fiberglass tiles. |
Posted: Mon Feb 14, 2011 6:10 am Post subject: |
joberg wrote: | Wrong tile: the deep groove at the right hand side of this tile should be at the top. Beware: not a screen used tile There's enough pics out-there from the movie for people to see clearly the design used in Deck's apt. People from the production took plaster molds of the real deal: Ennis house in L.A. and made either vac-formed or fiberglass tiles. |
It looks like a cast of one of the Ennis house replica tiles (they sold the 'mirror image' versions used in the house).
Heres the link to the Screenused site - the tile is bottom right of this page.
http://tinyurl.com/66z6b72 |
Posted: Mon Feb 14, 2011 8:41 am Post subject: |
As I explained before: the tile has a few features that makes it difficult to have a mirror image of it (let's say by simply rotating the tile)
First: the small square is at the bottom left-hand side and the deep groove is at the top of the tile (original design).
Second: to do a mirror image of this design you have to re-create an entire new tile (small square at the right- hand side with the deep groove still at the top of the tile as to respect the original design (you'll see those inside Ennis house).
Third: at Ennis house, FLLW also rotated tiles on the facade so now you have the small square at the right hand side and the deep groove at the left-hand side.
Fourth: the design used on the set of BR was off the original design: small square at the bottom left-hand side and deep groove at the top of the tile.
I haven't seen any rotated tiles in the movie (then again, I could've missed something and somebody will come up with a screen cap showing that I'm wrong ). |
Posted: Mon Feb 14, 2011 7:39 pm Post subject: |
joberg wrote: |
Yeah, thats what I meant. I wonder whether Screenused were hoodwinked or were being a bit devious themselves?
It'd be interesting to see what the authentication actually says.
This 'reverse' design they are selling is nowhere in the movie as you say. |
Posted: Mon Feb 14, 2011 11:08 pm Post subject: |
Considering how many movies and TV shows these tiles were used in, they probably came from a prop house and were just assumed to be Blade Runner. They look vintage though. The ones in BR look painted and rougher edged, not Vac Formed in the faux stone sheet. I agree that this one was probably not used in BR.
Posted: Tue Feb 15, 2011 5:21 am Post subject: |
Weren't the ones in the film done using styrofoam? I could swear I remember reading something about that in Future Noir. _________________
Posted: Tue Feb 15, 2011 8:20 am Post subject: |
I don't know if those in the film were either vac-formed, or they used a silicone mold and expanding foam (whatever is faster/cheaper for the production). There's a lot of techniques that you could use to make those and, I would think that, at least for the flat tiles in the apt. they would've used med density styrofoam and used either straight spray-paint or acetone to give a "distress" stone-kind-of-look to those (regular spray or acetone eats the foam and can make for interesting weathering look).
If you look closely at the prod-pics, you'll see that the more intricate tiles are generaly without holes or frayed edges, while the flat ones have some holes and are, generally in a more "used" state  |
disneytoy
Posted: Tue Feb 15, 2011 10:29 pm Post subject: |
Hi!
I just found this site. I love these blocks. My uncle was a location manager, And I got to go and take pics in the house when he was scouting. I purchased 2 tiles at the house so I believe they came from the tin molds on display.
The blocks do not hold up very well. The exterior of the house was in quite disrepair. Significantly smaller than you'd imagine. But there is a very long hallway with nice windows. I'll post some pics of my blocks if anyone likes. They are VERY heavy.
Max _________________ Maxi Claudio |
Posted: Wed Feb 16, 2011 8:18 am Post subject: |
Welcome aboard Max...yeah we love pics and stories about the movie from people/professionals who worked for the production  |
Dorian Gray Community Member
Posted: Wed Feb 16, 2011 2:09 pm Post subject: |
I'm surprised there isnt a pepakura file out there yet. |
Posted: Wed Feb 16, 2011 2:20 pm Post subject: |
True Dorian, considering that there's Pepakura for just about anything these days (Iron Man is an example) it would be fairly simple to make one. |
Posted: Wed Feb 16, 2011 2:22 pm Post subject: |
I'm going to see what I can do. I'll try to reach out to my pepakura friends for some assistance. |
