WTB-Resin cast pump widget-SORTED! no longer needed :)
rupetype266
PostPosted: Tue Mar 01, 2011 2:40 pm    Post subject: WTB-Resin cast pump widget-SORTED! no longer needed :) Reply with quote
As per title I'm after a resin cast of the sphygmomanometer pump widget for my real parts Aliens motion tracker build.
I'd even settle for a real one Very Happy
Any help would be greatly appreciated.
Many thanks, Rupe.
PostPosted: Wed Mar 02, 2011 8:12 am    Post subject: Reply with quote
Maybe a pic of the piece would help us locate the wigget in question Wink
rupetype266
PostPosted: Wed Mar 02, 2011 2:54 pm    Post subject: Reply with quote
Hi Joberg, I'll try and get a shot of the one on my MR Motion Tracker as soon as I can. I've thought about removing the one off the MR version to make a silicone mold but I don't fancy damaging it, it looks like its held on with screws but you never know with Master Replica stuff it could be stuck on with dummy screw heads or something?
PostPosted: Thu Mar 03, 2011 9:00 am    Post subject: Reply with quote
Possible that it could be a dummy screw...but I would try, gently, to remove it and make a mold if successfull ...maybe on the RPF in the junkyard or one of the builder (in France...erv is the name) is building one right now. You could try to contact him?
rupetype266
PostPosted: Thu Mar 03, 2011 3:31 pm    Post subject: Reply with quote
Cheers Joberg, I did actually manage to locate one last night so the hunt is over. At least it means I dont have to mess around with the MR one, I'll post up some photos in the Aliens section once I finally get started. Just need to hope that Erv does a run on his Motion Tracker electronics to bring the prop to life Very Happy
All the best, Rupe.
