jameth Community Member
Posted: Sun Jul 17, 2011 5:35 am Post subject: Esper Machine research |
Been researching the Esper machine. The hero one, not the "fake" or "Side View" one.
Here is what I have found:
Handle to the left side top is a Sunpak 522 flash
The lower left has a SX-70 Sonar Polaroid Camera
Upper right has two Braun Alarm clocks model Type 4 821
Top machine may or may not be some type of CED player (Capacitance Electronic player)
That's all I got.
Wondering about:
Size and type of TV
Top machine
Etc.
Posted: Sun Jul 17, 2011 5:44 am Post subject: |
So far so good Jameth...if you want more info, Nick Daring has posted on the RPF a very good list of what's what on that famous prop (some pics and discussion on Propsummit as well).
T.V. model or make is still unknown alas as well as those machines on top (I did a repro a year ago...should be transformed with the lights, but I haven't got the time to do so); the search button is your best friend in that case: it was under Studio Scale. Good luck with the search  |
Posted: Sun Jul 17, 2011 5:51 am Post subject: |
Been searching like a mad man. Actually Nicks thread on RPF is where I started.
Nick says the two alarm clocks are both the same but I'm not so sure. They look like they are different sizes. The lower one seems wider |
Posted: Mon Jul 18, 2011 11:27 am Post subject: |
Does anyone have the flash from the Esper????? Maybe it can be used to determine screen size???? |
Posted: Mon Jul 18, 2011 1:45 pm Post subject: |
The fake Esper screen that is believed to be the Hero screen just turned sideways has a clear plexiglass cover over it. It's not on the Hero but it is on the fake. |
Posted: Mon Jul 18, 2011 2:01 pm Post subject: |
I think Nick is correct and the fake was used to build the Hero. The Hero looks custom but the fake looks like a found item. However I have never seen a TV shaped like that. So I don't think it's a TV. I think maybe the whole thing Including the "VCR" is one unite.
What would have a narrow screen, with those controls on the right and maybe the whatever on top but not be a TV?????????? |
Joined: 01 Nov 2006 Posts: 6231 Location: Rochester, NY
Posted: Mon Jul 18, 2011 10:54 pm Post subject: |
From looking at the controls, there seem to be at least three different set ups used for the Esper.
Posted: Tue Jul 19, 2011 7:09 am Post subject: |
My plan is to go with the pics Nick posted on the RPF (first shot). I was going crazy trying to come up with a mix of both Esper used in the movie.
Now that my brain is clear I feel much better. Screen is a mystery (maybe a radar screen front on top of a video unit?). Andy is right: many types of buttons and grill for the controls at the right hand side of the unit.  |
Posted: Tue Jul 19, 2011 12:02 pm Post subject: |
But the base for the controls is the fake Esper machine as well. Look at the grill and lower buttons. They are wider on the fake and then turned so they are longer and look farther apart then additional stuff added in between.
I don't think they would scratch build it twice. The Hero looks scratch built. The fake looks manufactured. They used a complete unit first. I'm sure of it. Maybe even with the "VCR" as part of it. Turned the screen and ditched the cover. (I have an RCA TV that has an additional plexi cover over the screen). Then flipped the controls as well.
We need to know what that darn fake Esper is. Anyone got a good shot on Blueray??? It looks like there are markings on the upper left corner of the "VCR"
I also noticed pausing seems to be clearer than screen grabs (Forgive my ignorance if this is widely known. I'm a tech dufas). But I noticed when I paused it on Deckard's desk vidphone it was much clearer than any screen grabs posted so if someone with a blueray could go and look at the Esper both when he is standing next to it in his coat and when he is using it that would be great. |
Posted: Tue Jul 19, 2011 12:16 pm Post subject: |
There is an additional section below the controls on the fake Esper. It's cut off in the posted screen grabs. There is the grill (Flipped on the hero) then a small section of buttons (Extended on the hero) then the little section of what looks like a bunch of matching black buttons, etc (Again flipped on the hero) then another section. Looks smooth but can't quite see. If your turn you head I think this unit has the screen on top and the buttons and speaker on bottom. Anyway the fourth control side section may make it easier to locate. |
Posted: Tue Jul 19, 2011 12:29 pm Post subject: |
Could the top "VCR" be a paper shredder? The sound sounds like a paper shredder in reverse. Spits out the pic. Could be added in and a crewman pushing it out from behind or might be a paper shredder in reverse and they used the sound.
Also the lower Braun alarm clock has a light on the right side. |
Posted: Tue Jul 19, 2011 12:44 pm Post subject: |
Maybe a vintage document scanner or fax machine??????? |
Posted: Tue Jul 19, 2011 12:51 pm Post subject: |
All these are very possible, but without additional screen grab, or continuity pics (maybe Nick has more of those?)it's impossible/difficult to say  |
Posted: Tue Jul 19, 2011 3:47 pm Post subject: |
The sound is driving me nuts. I know I have heard that exact sound. Probably added in but maybe not. Might help with ID. |
Posted: Tue Jul 19, 2011 4:12 pm Post subject: |
Pretty much all of the sounds were added on later. I seriously doubt it is a clue at all to the origin to the "printer".
I think the top "printer" is likely something like a laminator, paste-up waxer, dot matrix printer, Laser Disc player, or something else of the vintage that would not be very common outside an art department,or AV department. It also almost looks like they took the face plate from the set (fake) version and then made a Vac form mold of it for the close up version. The color on it seems more uniform to the rest of the set up, and the edges seem just a tad bit softer. Either that or they just painted it, but if it is a valuable piece of equipment just filling in on set, it would make sense for them to recreate it, and not destroy it.
The bezel on the monitor seems removable too, and I would not be surprised if it was a part of modular control room set up. If the hypothesis of the set/fake version is that is an as is found item, the fact that the monitor is set up vertical instead of horizontal, it would mean it could be from medical or scientific equipment, instead of video equipment. Unless that version of the Esper body was put on it's side. I am still not sure though that they are the same parts, the bezel on the one is missing, and it has a kind of face plate or something over it from at least one photo.
The extreme close up version seems to be something all together different, and was likely the same one used for the snake lady monitor close ups. that one for sure looks "As Found".
Posted: Tue Jul 19, 2011 4:13 pm Post subject: |
Anyone own the movie Weird Science. They had a "scanner" they were feeding pics of female body parts into. I think it was like the Esper "VCR". |
Posted: Tue Jul 19, 2011 4:36 pm Post subject: |
Okay forget all those crappy ideas of mine. Looked at thousands of models of all of them. I think Nick was on the right track with the CED machine. In his RPF thread he has a link to a bunch of different models. The Zenith and RCA are the only ones that have a switch on the right side like the Esper "VCR" |
