Ophenix
Posted: Sat Sep 10, 2011 9:08 am Post subject: Which blaster? |
Hi all,
I'm planning to sell my blaster but i'm not sure which version i have. Can you guys help me out?
Here is pictures of the blaster.
Thanks. |
Posted: Sat Sep 10, 2011 12:52 pm Post subject: |
It may help if we knew who you bought it from, and when. I'm going to guess a Sidkit Worldcon, but it's only an uneducated guess ... |
Posted: Sat Sep 10, 2011 2:17 pm Post subject: |
It does look like a Sidkit. It could also be a combination of parts, or have some upgrades. Most likely a Sidkit though it could be combined with some newer Coyle parts as well. Doesn't look like a Coyle Worldcon though. I don't have my photo reference with me right now.
Ophenix
Posted: Sat Sep 10, 2011 2:50 pm Post subject: |
Yeah, i also did some research and it looks like it's a plastic Sidkit.
What do you think it's worth?
Thanks. |
Posted: Sat Sep 10, 2011 4:33 pm Post subject: |
I don't know of any such thing as a plastic Sidkit.  |
Posted: Sat Sep 10, 2011 5:47 pm Post subject: |
Plastic Sidkit Very unlikely, unless it's a re-cast from a metal one. From the pics it seems in metal to me. |
Ophenix
Posted: Sat Sep 10, 2011 6:30 pm Post subject: |
Hmm okay, maybe it isn't a Sidkit?. But i'm sure it's made of plastic. |
Posted: Sat Sep 10, 2011 7:48 pm Post subject: |
Plastic or metal it is a Sidkit copy of my model 4.
The six screws holding the pistol to the grip is mine.
Posted: Sat Sep 10, 2011 7:51 pm Post subject: |
What in the world happened to the side covers??
Posted: Sat Sep 10, 2011 7:56 pm Post subject: |
racprops wrote: | Plastic or metal it is a Sidkit copy of my model 4.
Rich |
Give it a rest Rich..
The Sidkit is available from Michele as a full resin (plastic?) kit as far as I'm aware and it might be this version you own.
Certainly there have been adjustments made to your build but I suspect thats what you have there..
Regards
MARK _________________
Posted: Sat Sep 10, 2011 9:02 pm Post subject: |
The current Sidkits being made by his protoge' Michelle, are allmost all resin again.
Posted: Sat Sep 10, 2011 9:13 pm Post subject: |
I was pointing out that I could tell what it was by the fact it was a copy of my design and only my early model and the copy Sid made HAD those features.
You give it a rest.
The fact that Sid copied my model is a FACT. He admitted it and so on.
I have nothing to prove.
But as no one seemed able to ID it I did.
Posted: Sun Sep 11, 2011 7:42 am Post subject: |
If it's all plastic, then you had me fooled with the pics...thought it was pewter/metal  |
Posted: Sun Sep 11, 2011 10:22 am Post subject: |
Richard, I find it odd you should refer to it as "your design," since you copied it from the movie. |
Posted: Sun Sep 11, 2011 10:34 am Post subject: |
I am talking about the changes I did befor we knew what was under the grips.
To make a stronger mounting of the gun frame with all those parts hanging off the grip frame so I added extra screws.
Only my model and Sids had these extra screws.
So that is my designed change.
It is the same story with the bolt, I worked out how it MIGHT have been and made a bolt where none ever were...my own design, so when it is copied I can see my design.
