A New Snub Nose Blaster from Goldberg Arms
Goto page Previous  1, 2, 3 ... 13, 14, 15, 16, 17, 18  Next
DaveG
PostPosted: Tue Sep 20, 2011 12:13 am    Post subject: Reply with quote
Bwood wrote:
There is no visible screw in the safety switch. Theoretically then, what secures this part to the weapon? Confused
I went back to the look of the original un-modified Steyr thumb slide, which doesn't have a screw drilled through it's face to hold it on. The slide is held internally. Much more graceful, IMHO! Again, if you look back at some of my early posts about my design, I was going for a gun that looked as much like a real manufactured weapon as possible, not a replica of the hero prop.
Dave
DaveG
PostPosted: Tue Sep 20, 2011 12:19 am    Post subject: Display Stand Reply with quote
Here's the finished prototype for the display stand, Three laser cut pieces which interlock, no glue required. The engraving is done in reverse with the CNC router. Under the right lighting it "light pipes", almost looks like neon!
I'm not sure yet what the price will be, depends on how many I make.
Dave
PostPosted: Tue Sep 20, 2011 7:02 am    Post subject: Reply with quote
Beauty Cool ...now that's what I call a gun stand!
PostPosted: Tue Sep 20, 2011 10:00 am    Post subject: Reply with quote
Dave
Thanks, Dave. Now I'm wondering why they ever put a screw through the switch on the Hero blaster ...
PostPosted: Tue Sep 20, 2011 6:46 pm    Post subject: Reply with quote
The one on the Steyr goes down in through the stock, and is part of a much larger piece. It would interfere with the cylinder if it was whole. I think they had to pretty much cut it off and attach it directly to the receiver as a simple solution. I like Dave's solution better myself, and agree it makes the gun much cleaner. I kind of wish the screws on the Grips were gone too (or moved to a less fragile location).
Still this thing is a masterpiece, and it has been great seeing it develop here from the from it's inception. Outstanding work from start to finish, and from top to bottom.
PostPosted: Tue Sep 20, 2011 7:44 pm    Post subject: Reply with quote
I agree, it is a thing of wonder.
Daddy Solo
PostPosted: Wed Sep 28, 2011 10:08 pm    Post subject: Reply with quote
***Pic Heavy**** I present to you my new BR snubbie. I decided to go with a black finish and gave it some slight holster wear. Big thanks to DaveG. What an awesome kit! It was so much fun to build.
Preop pics:
metallic silver base coat:
final paint/assembly:
It's new home:
Now all we need is that awesome acrylic stand to go with it
PostPosted: Thu Sep 29, 2011 7:03 am    Post subject: Reply with quote
Good work on that one (and very nice display also Cool )
DaveG
PostPosted: Thu Sep 29, 2011 9:10 am    Post subject: Reply with quote
Excellent work! The Black and Ivory make a stunning combination.
Dave
DaveG
PostPosted: Sat Oct 15, 2011 9:30 am    Post subject: Reply with quote
Just a little update... there are still a few kits from the first run available. Some of the molds have broken down so I'll need to make new molds in order to do another run of kits. But I won't have the time to do this until after the first of the year. This is by way of saying, if you were thinking of the Snubby as the perfect Christmas gift for the Blade Runner fan in your life (or yourself), don't delay!
Another note about the next run, the clip holder and clip are likely to be molded in one piece. The double set of three part molds was just way too time consuming to redo again. This will mean no removable clip for LED conversion. So if you were thinking about adding electronics a first run kit is the only practical option.
Dave
Daddy Solo
PostPosted: Sat Oct 15, 2011 9:36 am    Post subject: Reply with quote
any progress on the acrylic stands. My snubbie is currently laying on its side in my display case feeling neglected. All my other blasters make fun of "the little guy" Laughing
DaveG
PostPosted: Sat Oct 15, 2011 9:55 am    Post subject: Reply with quote
That "Little Guy" can kick their a...
oops, sorry!
I made a half dozen of the stands but when I inspected them closely, they all had some scratches since the plex had be stored without the masking paper on one side. I have been too busy to pick up a new sheet of plex. It's on the "to do" list!
Dave
EricC.
PostPosted: Fri Dec 30, 2011 1:44 pm    Post subject: Reply with quote
Hi Dave, can you email me info about the kit or the next run if you're sold out?
Thanks, Eric
DaveG
PostPosted: Tue Oct 02, 2012 9:15 am    Post subject: Last two kits left! Reply with quote
I am down to my last two snub nose kits from the first run. When these are gone... I will make more, but I don't know when. And these are definitely the last to have the removable ammo clip. So if you've been on the fence about getting one...
Dave
Robotprops
PostPosted: Tue Oct 02, 2012 9:46 pm    Post subject: Reply with quote
Any chance of getting a "clearance" price?
DaveG
PostPosted: Wed Oct 03, 2012 9:57 am    Post subject: Reply with quote
Sorry, no,
Dave
PostPosted: Wed Oct 03, 2012 12:39 pm    Post subject: Reply with quote
Dave
are you going to make more of the stands?
ANy progress on the other two models you where working on?
DaveG
PostPosted: Thu Oct 04, 2012 9:08 pm    Post subject: Reply with quote
hirohawa wrote:
Dave
I doesn't look like the stands are going to happen, at least not for a while. No progress on new models. Too many other things to do!
Dave
Robotprops
PostPosted: Fri Oct 05, 2012 1:38 am    Post subject: Reply with quote
I bought one.
Thanks Dave. I feel like a kid on Christmas morning waiting for it to arrive.
PostPosted: Sat Oct 06, 2012 1:09 am    Post subject: Reply with quote
Good stuff Robotprops; eager to see the built/finished prop
Page 14 of 18
