Vader Community Member
Posted: Fri Jan 20, 2012 2:55 pm Post subject: |
Looks sweet — I'm looking forward to getting mine! _________________ 26354 |
Daddy Solo Community Member
Posted: Fri Jan 20, 2012 8:21 pm Post subject: |
berry berry nice  _________________
Posted: Fri Jan 20, 2012 8:44 pm Post subject: |
Looks cool Rich. I like the "wireless" ammo clip.
Posted: Fri Jan 20, 2012 8:47 pm Post subject: |
And it has a top..
Posted: Sat Jan 21, 2012 10:12 am Post subject: |
Aaahh, one day I'll have one of those TFS Rich  |
Posted: Sat Jan 21, 2012 10:25 am Post subject: |
Don't wait too long..or you might end up paying a lot more once I am retired or gone..I am 63 and having health problems...last year was no fun...
Posted: Sun Jan 22, 2012 3:31 pm Post subject: |
The video is an improvement over the first version. And somehow, the blaster also manages to look even better. _________________ 26354 |
Posted: Sun Jan 22, 2012 3:59 pm Post subject: |
Thanks, the first one was shot indoors the second was filmed outdoors with real sun light...
And I cleaned up for the film...
Posted: Sun Jan 22, 2012 6:50 pm Post subject: |
Yep, looking much better for sure...and Rich, please, don't retire yet: I'll need that gun one day  |
Posted: Wed Jan 25, 2012 9:49 am Post subject: |
I went with the Rem 222 round for the same reason there is 44 rounds in the Bulldog, I am doing a on the set version of the prop.
That is accurate to what was used on the set. And as "they" used stock Steyr ammo clips and only added the LEDs, even to keeping the feeding gate part of the clip, the upper part, that HAS to be cut down to really fit into the housing with the Bulldog's barrel running though the top..
Well they seemed to be using a stock clip so it could be loaded with stock rounds the Rem 222, so that is what I did, only I did make my clip lower so it will clear that pesky barrel.
As I needed to glue the back plate and it then holds the top in with a screw and hold the contacts for the side rod's power, I never even considered clear plastic..and I feel it would look less real IF you can see inside and see the LEDs and battery .
jameth Community Member
Posted: Wed Jan 25, 2012 8:18 pm Post subject: |
Rich how much is the upgrade ammo clip and housing as a kit?
Also how much would each additional ammo clip kit be?
Thanks |
Posted: Wed Jan 25, 2012 8:47 pm Post subject: |
The Built version of the new ammo housing with removable clip is $55.00.
The kit verson of the ammo housing with clip and all parts is $35.00
This ammo housing should fit all of my models.
The price for the new metal bolt with cocking lever is $35.00.
Finished out and treated is $55.00
There is some fitting of the bolt and rear cap to the Steyr receiver.
On a 2011 model labor is included. (Free) (IF you want me to fit these new parts)
On 2010 labor will be $10.00
On older models $25.00
And I have plastic verions of the bolt and cocking lever as well so you might be able to fit these new style bolts to older plastic models...
Price for plastic bolt and cocking lever is $25.00
Shipping is extra.
Posted: Thu Jan 26, 2012 10:28 am Post subject: |
racprops wrote: | The Built version of the new ammo housing with removable clip is $55.00.
Shipping is extra.
Rich |
Great, I'm working on scraping up some funds.
How much for extra clips?
I want to get the housing/clip set up and then have extra clips. Figure three extra so four total clips.
I need to get all kit versions.
Thanks |
Posted: Thu Jan 26, 2012 10:32 am Post subject: |
Figure on $25.00 per each clip.
Posted: Thu Jan 26, 2012 11:12 pm Post subject: |
Great, I'm waiting on payment for a run and nead to square a few things away.
I'll send a PM when I have funds.
Thanks |
Posted: Fri Jan 27, 2012 8:26 am Post subject: |
As I am just starting on the next run that should work out fine.
RIch _________________ I never have enough time to do all I want to do! |
Posted: Fri Jan 27, 2012 10:23 am Post subject: |
racprops wrote: | As I am just starting on the next run that should work out fine.
RIch |
Great,
I should be able to send payment in 3 to 4 weeks.
I will need a kit of the housing and 4 clips.
Thanks |
