Ki-Djowac Community Member
Posted: Wed Mar 28, 2012 7:07 pm Post subject: |
Good stuff...and a mirror image of the top tile is also a nice addition.
Don't forget the deep groove on top to make it screen accurate.
Eager to see the result with the gun  |
Posted: Thu Mar 29, 2012 12:42 am Post subject: |
a deep goove ? Indeed, i did some more research and it's missing something, thx for the feedback.  |
Posted: Thu Mar 29, 2012 4:06 pm Post subject: |
Model adjusted and updated first post  |
Posted: Thu Mar 29, 2012 4:46 pm Post subject: |
Oooops...wrong side. When you look at the tile (same position as in the movie) the small square should be at the bottom left hand side and your deep groove should then be on top of the main ridge.
Now, your tile has the deep groove on the right hand side of your main ridge. I'll post pics later 'cause I'm using a different computer that hasn't my files on it. |
Posted: Fri Mar 30, 2012 12:30 am Post subject: |
Indeed, it is as you say.
There seem to be 2 kind of tiles floating around on the web. One with the groove on the right side and one on the top. I'll look at the film again this evening to make sure which one it is.  |
Posted: Fri Mar 30, 2012 6:59 am Post subject: |
Since the set designer took molds of the real tiles at Ennis House in L.A. you could just Google that and get the right design  |
Posted: Fri Mar 30, 2012 9:27 am Post subject: |
Yup, done, but even then it's tricky to separate real from fake. Nevertheless, my next revision will be the right one  |
Posted: Fri Mar 30, 2012 10:46 am Post subject: |
Looking good man. The ones on the Ennis house were made in both orientations, but they only copied one tile from the Ennis house to make Deckard's apartment. They used the one that is a mirror to the one you made here. Check out pics from the movie to see what I mean. Hopefully the program you are using as an easy flip function on it. It should. Only us sticklers notice this stuff though.
Posted: Fri Mar 30, 2012 12:37 pm Post subject: |
Thx, glad you like it and thx for confirming.
I just came back from a tile search downstairs through the final cut of Blade Runner and took some photo's of my TV screen
I'm actually new to 3D drawing and started last weekend with it so i'm learning as i go along. I'm using the free version of google sketchup.  |
Posted: Fri Mar 30, 2012 3:47 pm Post subject: |
Ok, third revision done.
Updated first post again and made it 1/6th scale while i was at it too taking into account that the original tile measured around 16 inches by 16 inches. Let me know what you guys think  |
Posted: Sat Mar 31, 2012 3:23 pm Post subject: |
Yes! That's it. Now it's accurate  |
Posted: Sat Mar 31, 2012 4:17 pm Post subject: |
Hehe, thanks
As for the blaster stand i'm going with some ideas and it's far from finished. But the idea for the wall behind the blaster is this for now :
Imagine some red EL strap behind those letters. The tiles, possibly the whole thing may be printed in sandstone although i'll probably order a test tile first to see what sandstone actually is. Thoughts are still racing through my mind so things may change alot before i have something final  |
Posted: Sun Apr 01, 2012 8:45 am Post subject: |
I can imagine alright...you said it's for displaying your gun, sooo I guess those tiles will not be 16''X 16"?  |
Posted: Sun Apr 01, 2012 12:20 pm Post subject: |
awesome work... and i love sketch-up as well!!! ANYTHING 1/6 scale gets my attention!  _________________ I've had people walk out on me before, but never when i was being so charming |
Posted: Sun Apr 01, 2012 3:29 pm Post subject: |
A 16 x 16 inch printed tile, that would be something. I wouldn't wanna be paying that bill though
Thx, yup, as it turned out with my first 7 x 7 cm tile i was not too far off to go for 1/6th scale anyways (if the originals were 16 x 16 inches).
As for the base, i managed to get some more work done today and i think i'm nearing the end of the whole stand idea. The base will also have a slot to put the ID in i purchased from Synamax. Great work by the way.
http://www.propsummit.com/viewtopic.php?t=3585
Behind it, the gun itself will stand horizontally with a 10mm polycarbonate rod lighted up with a 5mm clear white LED under the base, vertically under the front allen screw. The butt end will sit slightly flush inside the base.
I'll be grouping an order soon and see the mats first hand before i decide to go all out and order the whole base. Keep you posted. |
Posted: Sun Apr 01, 2012 6:50 pm Post subject: |
Sounds good, looking forward to it  |
photek Community Member
Posted: Sun Apr 01, 2012 8:18 pm Post subject: |
I never get tired of seeing these tiles in any incarnation. Great job man! _________________ two legs bad, four legs good. |
Posted: Wed Apr 25, 2012 3:12 pm Post subject: |
Thanks for the compliment
Got the order i talked about 3 posts before coming in tomorrow. Eager to see how sandstone turned out as it's the first time i've ordered that material. Keep you posted and i'll put up pics by the end of the week. |
Posted: Wed Apr 25, 2012 4:39 pm Post subject: |
| Sounds good...did you ask a local business to do it or is it outside of Belgium? |
