Posted: Wed May 23, 2012 12:26 pm Post subject: Prometheus flashlight found item |
I figured the flashlights seen in the trailers so far, were found items.
And sure enough I googled up a match! Ultrafire 18WG-T60
About $30 online.
k
Last edited by phase pistol on Wed May 23, 2012 7:47 pm; edited 3 times in total |
Brownclaw Community Member
Joined: 04 Aug 2011 Posts: 168 Location: United Kingdom
Posted: Wed May 23, 2012 12:58 pm Post subject: |
That's fantastic, thank you!  |
Posted: Wed May 23, 2012 6:25 pm Post subject: |
Excellent research!...but stop me if I'm wrong but it seems that on the last pic with David the outside rim on the lamp part is grooved, while on the product pic it's not.  |
Posted: Wed May 23, 2012 7:45 pm Post subject: |
Good point and I don't have an answer to that. Mine (which I got from Dealextreme) has a screw-off rim at the end, and in my pics it's removed.
If there is another version of this, or a flashlight that this is a knockoff of, I'm not aware of it.
Perhaps the prop flashlights in the film have got a different rim screwed onto the end.
k |
Posted: Wed May 23, 2012 10:24 pm Post subject: |
OK I figured out the mystery of that different-looking rim on the lamp end of the prop flashlight (as opposed to the petaled end of the Ultrafire)...
it seems if you take off that petaled end rim... the lens will fall out!
So either they ground down the rim, or replaced it with a different part... something to keep the lens from falling out.
(or I got the wrong flashlight... ) |
Posted: Thu May 24, 2012 4:01 am Post subject: |
| Thinking outside the box a little here, but are we sure there are actually lenses present in the movie stills? |
Posted: Thu May 24, 2012 7:03 am Post subject: |
Good point Brownclaw...difficult to see from the screen grabs, but I don't see why they would remove the lenses I know that pieces of glass/plastic can reflect lights/crew and such, but since those are lit it has no more importance in terms of "reflection" problems. |
Gero Community Member
Posted: Thu May 24, 2012 9:53 pm Post subject: |
That's certainly a good match, Gero!
Tho it looks like the only real difference is the flat bezel, instead of the scalloped "strike" bezel...
Posted: Thu May 24, 2012 10:08 pm Post subject: |
I emailed the company to see if I can buy just one of the bezel rings... let's see if they reply.
k |
Posted: Fri May 25, 2012 2:36 am Post subject: |
Great work guys, thanks for sharing !!!
Posted: Fri May 25, 2012 3:50 am Post subject: |
Awesome work and great hunting  |
Posted: Fri May 25, 2012 7:52 am Post subject: |
Good work people now let's see if the company will respond and have the "lined" lamp ring  |
Posted: Fri May 25, 2012 2:28 pm Post subject: |
So one question is, did MTE make a silver version of the SSC P7. Or did the production just buy black flashlights and paint them (which admittedly would get rid of the logos on the sides as well...).
And the other question is, did MTE manufacture and sell these under the UltraFire name also, or is UltraFire a copy by a different company (the two brands seem to sell for about the same price though, so there's not a lot of money to be saved by getting the copy if that's indeed what it is).
k |
Posted: Fri May 25, 2012 3:04 pm Post subject: |
MTE is a company based in Singapore, Ultrafire is a company based in Hong Kong. Who is here copied from whom is the question.
Both are, however, own manufacturer.
MTE provides on request, in any color you can anodize. The number is crucial.
In the German Torch-Forum the MTE torches is always referred to as the original. This is probably because the MTE models appear before the ultra-Fire.
The guys in the forum are just as crazy in Flashlights as we are in Blade Runner.
And they are just as competent. So I think that MTE is probably the original. _________________ "...ist sie teuer?" "Außerordentlich!" |
Posted: Fri May 25, 2012 7:29 pm Post subject: |
Excellent Gero Karl: probable they've been painted as to not show the logo as you said...or take a silver flash light and just replace the ring with a dented one (less to paint). |
Posted: Fri May 25, 2012 7:51 pm Post subject: |
I agree with Gero's reasoning, probably the movie flashlights are MTEs.
And I'm guessing they are painted... hard to be 100% certain but it looks to me in that shot of David grinning at the little dancing things (which is freaking me out btw) it does look like there are some dark spots on the flashlight, where perhaps the silver paint is rubbed off.
I got a response from MTE, they wanted me to send photos of my flashlight so they can be sure to give me the right bezel... hopefully they will not be upset that my flash is an Ultrafire and not MTE.
k |
Posted: Fri May 25, 2012 8:15 pm Post subject: |
| phase pistol wrote: | ... hopefully they will not be upset that my flash is an Ultrafire and not MTE.
k |
maybe they can not distinguish themselves  _________________ "...ist sie teuer?" "Außerordentlich!" |
Posted: Sat May 26, 2012 10:52 am Post subject: |
So I heard back from MTE, they say they could send me just the bezel ring, but "maybe the freight is too expensive" and would I be interested in buying a flashlight.  |
