Replicant 13 Community Member
Posted: Tue Aug 14, 2012 8:01 pm Post subject: BRONZING DAFFY |
All -
Bronze is a nice thought. However, I have no experience with this process. As Joberg said, of course, it would depend on the cost. I may investigate this further, perhaps - perhaps - do a limited run
My thought was to keep the cost down so more could afford the duck, offering it as a simple kit, requiring a minimum of work to complete. The finish would therefore be at the owners discretion. But I suppose you could have it bronzed/plated like they used to do with baby shoes.
But my motivation here was simply to create a more exact replica, since the actual weights you find online seem to all differ significantly. It seems no two are identical, although in the past a couple seem to have come close to Deckard's.
HAB1! - R13 _________________ Gosh, you've really got some nice toys here . . . |
Posted: Tue Aug 14, 2012 8:13 pm Post subject: CASTING IN BRONZE |
I thought that it might involve the "lost wax" process. I took a quick look and found this on YouTube. Interesting and something worth learning, no doubt, but a lot more involved (and obviously more expensive) than casting in resin.
And a bit impractical with my setup.
http://www.youtube.com/watch?v=jFOo5EWNl8M
Perhaps cold-cast bronze - a blending of bronzing particles and resin might be an option . . .
BR26354 Community Member
Posted: Tue Aug 14, 2012 8:38 pm Post subject: |
VERY interested if this project turns into a "run". Gosh, you really have some nice toys here...well done!!! _________________ Replicants are like any other machine...they're either a benefit, or a hazard. If they're a benefit it's not my problem. |
panaflex Community Member
Posted: Tue Aug 14, 2012 10:07 pm Post subject: |
While a bronze run would be fantastic, I'm sure this would bump costs dramatically. Someone with the background could prob. do a small run but I'd be happy with a resin one I could shoot with paint and rub n buff, what have you... just my 2 cents. _________________ Hollywood is the only industry, even taking in soup companies, which does not have laboratories for the purpose of experimentation.
Orson Welles |
Posted: Tue Aug 14, 2012 10:46 pm Post subject: THE DUCK AND NOTHING BUT THE DUCK . . . |
The Plan, as it stands, is to finish detailing the duck, then cast it in black or brown resin, depending on how my test goes. From past experience, I think it might prove to be a waste to go the cold-cast bronze route that I suggested earlier. The result would probably be disappointing to most and still require paint and/or a metallic rub 'n buff finish to achieve the desired finish. If you look at some of the actual bronze weights online, there is quite a range of colors and patinas - from blacks, purples and blues to browns, golds and greens. This way the finish would be up to the collector.
While it can be slightly more expensive, with a darker resin you have a better base color and you avoid exposing a bright tan resin if the surface is scuffed or scratched in handling the prop. I have experienced this with other resin props and retouching these dings can become a hassle.
More later. Thanks for your continued interest.
jameth Community Member
Posted: Wed Aug 15, 2012 9:27 pm Post subject: Re: THE DUCK AND NOTHING BUT THE DUCK . . . |
Replicant 13 wrote: | The Plan, as it stands, is to finish detailing the duck, then cast it in black or brown resin, depending on how my test goes. From past experience, I think it might prove to be a waste to go the cold-cast bronze route that I suggested earlier. The result would probably be disappointing to most and still require paint and/or a metallic rub 'n buff finish to achieve the desired finish. If you look at some of the actual bronze weights online, there is quite a range of colors and patinas - from blacks, purples and blues to browns, golds and greens. This way the finish would be up to the collector.
HAB1! - R13 |
This is sooo cool.!!!!!!!!!!!
On the colored resin do some experimenting. I have a great resin I use but the instructions for the dye to make it the right color were way, way off. I had to use 20 times the amount to make it the right color which also made it the proper strength. Using their directions the resin came out light, kind of translucent and very flimsy.
Do a bunch of small tests to find out exactly how much you need first. X drops of color for X tablespoons of Resin, etc. As we know resin costs can add up fast.
Can't wait to see the finished project. Like others I have searched Ebay and the net high and low.
Maybe you can do the second forward facing one on the music stand as well. _________________ Tom |
Posted: Thu Aug 16, 2012 12:38 am Post subject: DYE HARD |
Jameth -
Yes. If I go the color route, it will indeed take some experimentation. Years ago I used Alumilite® resin to cast some head sculpts - adding a couple of "skin colored" dyes, but as you suggest, getting the balance right, while allowing for the color of the resin as well, can be tricky. I never was really satisfied with the flesh color I achieved. I'll have to run tests again and see.
That said, in this case, I think a pre-mixed black resin might still be best, since any metallic finish will have to be applied afterward, anyway.
Thanks for the input. - R13 _________________ Gosh, you've really got some nice toys here . . . |
Posted: Thu Aug 16, 2012 6:44 am Post subject: |
Not sure of the costs. My brother-in-law could cast a ton of those though in some kind of metal. Here's his website http://www.sculpturetrails.com/ Maybe we could work something out? |
Posted: Thu Aug 16, 2012 7:21 am Post subject: |
Rep13, did you use the white Alumilite or the clear one? |
Posted: Thu Aug 16, 2012 6:20 pm Post subject: UGLY DUCKLING |
I think if it were to be cast in metal, it would be less desirable if it were not in bronze. It would be interesting to know just how much it would cost to cast up a few of these in bronze. It's roughly under 3" cubed.
But again, to keep the costs reasonable, my intention is to proceed with the black resin.
To answer your question Joberg, at the time the most commonly available color of Alumilite® was the cream/tan color. Unfortunately, because of this, any added color was usually skewed to yellow.
HAB1!- R13 _________________ Gosh, you've really got some nice toys here . . . |
Posted: Fri Aug 17, 2012 10:55 am Post subject: |
Thanks, it's good to know for future projects |
Posted: Fri Aug 17, 2012 5:49 pm Post subject: DUCK POWDER |
Logical thought. I had considered that, having experimented with it years ago. I mentioned it here earlier, as well, but for the effort and the cost I think the outcome might still be disappointing.
If you don't add enough it looks like a metallic fleck; too much and it can weaken the casting. I'm no expert, but of the castings I've done in the past, it can also look rather monochromatic.
So all said, it usually requires paint or a metallic rub to age it and give it the right finish anyway.
I'll do a couple of tests. See how it goes.
Posted: Mon Aug 27, 2012 7:05 pm Post subject: ANOTHER LOOK |
It's difficult to see in these closeups, but while there may not appear to be much change I've added a bit more detail - although there seems little apparent in the actual piece.
No doubt there is more than can be seen in a blowup from a single frame capture. I've tried to reach a decent medium point.
(You can see here the cardboard "spine" running through the center of the sculpt.)
Posted: Tue Aug 28, 2012 7:16 am Post subject: |
Looks good to me Rep13...eager to see it finished in whatever medium |
Posted: Wed Aug 29, 2012 12:18 am Post subject: |
Awesome. Can't wait to see it finished. _________________ Tom |
Posted: Sun Sep 02, 2012 3:44 pm Post subject: FOUR PLAY |
Four views, prior to the initial mold -
Posted: Sun Sep 02, 2012 3:46 pm Post subject: |
A+ for sure |
Posted: Sun Sep 02, 2012 4:09 pm Post subject: |
I'll take one to go please.
Awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! _________________ Tom |
Posted: Sun Sep 02, 2012 4:10 pm Post subject: |
Sorry, it needs to be said again.
Awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! _________________ Tom |
