jargonking Community Member
Posted: Wed Nov 28, 2012 6:01 pm Post subject: |
TFS jargonking...I would've prefered a BR parking meter for the base, but I shouldn't be difficult right?  |
Posted: Fri Dec 07, 2012 4:54 pm Post subject: |
Here's some pics of the base which I've had for a while....what's impressive is the waves in the gutter and puddle caused by the downdraught from the Spinner take-off.....
Fresh in from the States today are the figures....
The instructions state that they are only suitable for a Spinner modified using the ParaGrafix etched set....
The figures come with fairly substantial, but easy to remove mould plugs attached....
Deckard with noodle bowl....the likeness isn't bad and will look fine when seen through the window....
Gaff has a separate arm and a prominent air bubble where his nose should be although this is an easy fix.....I may actually replace both arms as I want to model him using the Spinner's control gloves....
So that's everything I need to get started on my Spinner now..... |
Posted: Fri Dec 07, 2012 6:39 pm Post subject: |
TFS Jargonking...the resin didn't reach Gaff's nose and Deck's tie is in need of some dremel work to make it thinner, but besides that, it'll be a great project combined with the building of the Spinner (are you going to make it with open doors?)  |
