Posted: Tue Apr 16, 2013 2:45 am Post subject: Deckard Holster for Resin Blasters. Interest Thread. |
David, Replicant 13, came up with a really great idea.
He asked me if it was possible to produce a 'soft grip' Deckard holster specifically for painted resin replicas.
This is a great idea. I'm sure many replica owners have delicate resin blasters they wouldn't dare trust to a holster with a strong internal spring. I know I wouldn't
I would be interested in producing a 'soft' holster. I'm not certain how it would work yet, I'll need to do some testing and prototyping, to be sure I can retain the characteristic look of the original holster. It would be made of the same, screen accurate, leather and be hand made and hand stitched, and have the screen accurate stamping on the rear.
The internal clamshell spring on the original holster provides not only retention for the blaster, but form and structure for the holster itself. The spring gives the holster a lot of it's look.
At the moment, my plan is to make a holster which retains the blaster by means of a small, discrete, black leather strap across the open holster front. Almost invisible against the ammo clip, it could fasten to a stud on the back of the holster.
Soft suede lining would protect the finish.
of course, I need to be sure it can be accomplished, but would anyone be interested in this model?
Christian Jones Community Member
Posted: Tue Apr 16, 2013 3:19 am Post subject: |
| Very interested ! That's a great idea. |
Countrypaul Community Member
Posted: Tue Apr 16, 2013 4:45 am Post subject: |
Think this sounds like a great idea
I put my resin PKD2 into the fantastic premium holster that I got from yourself & heard a distinct crack as the bolt lever & sight rod fell off, oops
No harm done I just glued them back on
Not sure if the Resin Rick Ross PKD's are slightly oversized, think mine is a touch wider than my Offworld (but is the Aussie kit)
Given that the Rick Ross Resin kits are a unique interpretation of the Blaster I don't think the holster needs to be dead on screen accurate but I'm sure others will disagree (& not everyone will just want one for a Rick Ross, I realise that there are many resin blasters)
Personally given that my Resin kits are cheaper than the metal I'd sacrifice some screen accuracy for a better fit or a cheaper holster
Anyway, interested depending on fit & price |
Posted: Tue Apr 16, 2013 7:09 am Post subject: |
Karl, that's a great idea and maybe instead of lining the inside with suede, we could think of other soft liners: moleskin, or velour, etc...to make sure that the paint or the some parts will not come apart  |
Bassnoir Community Member
Posted: Tue Apr 16, 2013 10:37 pm Post subject: |
It is a great idea...I agree with Joberg on the material suggestion...I have a Rick PKD Magnum and would not even consider putting in my Phil S holster...for fear of breakage...but have no problems with my Sidkit Coyle and Offworld...on this track...Zhora's blaster is resin as well...right?...the Hartford snubbie is solid as a rock metal... _________________ ...the future is not all it's cracked up to be... |
Posted: Wed Apr 17, 2013 2:29 am Post subject: |
The credit for the idea itself must go to Replicant13 as he suggested it in the first place.
The suede inside shouldn't be an issue. The design is such that there should be no pressure at all on the blaster in the holster. The suede split I use to line the holsters is very soft.
I'll make it screen accurate size. With the original holster, the bow of the steel spring encroaches into the holster by a half inch in front of the spine. Without the spring, there's a little more room, so it should fit oversize blasters.
I've been busy with this already, and will have the prototype done today, hopefully.
I need to be sure I can get the correct shapes and forms of the original holster without the spring.
The retainer strap looks good. Very minimal. I doubt you'd even see it unless looking very closely.
I had to redesign the welt between the two halves. It's quite minimal on the original, but I thought to extend it up further below the open holster front. It'll add more security for the blaster and help recreate the correct shape. There are lots of other tweaks....
More as it happens,
Posted: Wed Apr 17, 2013 6:40 am Post subject: |
Good news Karl, cannot wait to see the mock-up  |
amfx74 Community Member
Posted: Wed Apr 17, 2013 8:54 am Post subject: Holster for painted blasters |
| I would be interested. It's a great idea. |
Posted: Wed Apr 17, 2013 11:37 am Post subject: |
Here we are then.
This is a prototype of the Deckard 'Soft Grip' holster I finished today.
It has no internal steel spring at all. The shape is formed by the cut, the new welt between the shells and by wet forming the holster.
I know there are a couple of tweaks. The strap has to move down by a quarter inch. One or two other niggles. I deliberately left out the extra belt slot, as it messes with the shape and creates a weakness on that side.
As a proof of concept, it works well. It feels secure and looks almost exactly like the premium holster. You can hardly see the retainer strap unless you look for it.
The blaster is an early Coyle, all resin. The holster has next to no grip on the blaster at all, it's an illusion.
The fit is just big enough to take the blaster, but there's so little pressure on it, that it will just fall out if turned upside down.
What do we think?
Karl
[/img]
Posted: Wed Apr 17, 2013 11:41 am Post subject: |
Having played with a number of holsters over the years I can report that holsters are hard on plastic models…
And that spring holsters are also problems.
First you really need a loose holster, more like a pocket for a plastic model, I would suggest a painted or died slot to get the look of an open spring holster for any plastic holster or cut out slots to give a somewhat opened slot.
I did a Galatica holster like this years ago in leather instead of the hard plastic they had used in the show. The Plastic shell holsters were damaging the models as they were drawn and holstered. Back in the 80s most of my models were used in cosplay, and I tried offering holsters for many of the models I did back then.
I stopped because of how many repairs I had to do due to holster damage. Classic hardened style holsters damaged models.
The Galatica holster I had done with soft leather, it did make holstering the model harder as the soft holster did not hold its open shape.
The spring holster can also be unreliable, I dropped a metal Blade Runner model at a con, it just slipped out. And it damaged the side rod being pulled and holstered.
AS I have said all along use a holster at your own risk, and I will not cover repairs due to holster wear or damage.
PS Proper: You may have done it....custom forming them to each model: BUT I think you will have to test and form them TO EACH model to be sure of correct fit. _________________ I never have enough time to do all I want to do! |
Posted: Wed Apr 17, 2013 12:56 pm Post subject: |
Thanks for the input Rich.
I did cover most of your observations in my posts.
The holster only APPEARS to be a tight fit, it hardly touches the model inside. Turn the holster over the model just slides out, no pressure on the model.
The black restraining strap stops the model from falling out and maintains the shape of the holster when fastened.
There is NO METAL SPRING in the holster at all. No spring. The spring pocket stitched in is for authenticity only.
The holster is fully lined with suede to protect the resin surface and paintwork.
I think there can be a preliminary fitting when they're made, then each model can be wet formed to exactly fit different model.
Karl
Posted: Wed Apr 17, 2013 1:04 pm Post subject: |
That covers it.
Good/Great job.
Posted: Wed Apr 17, 2013 4:22 pm Post subject: |
Karl, I cannot see your pic  |
Posted: Thu Apr 18, 2013 6:42 am Post subject: |
Karl, everything is fine now. It's a beauty for sure and very handy to have for the resin gun collectors around here  |
Posted: Thu Apr 18, 2013 7:26 am Post subject: |
Thanks Joberg,
As I say, credit to Replicant 13 really. It was totally his idea.
I think it will fill an important niche in the market.
Many of us have heard the sickening 'snap!'
If anyone has questions, or would like one, please get in touch.
I'm selling these direct.
UK only, GBP£99.00 shipped
Rest of the world, USD$149.00 shipped
Thanks,
Karl
Posted: Thu Apr 18, 2013 4:34 pm Post subject: |
You're welcome...and kudos to Rep13, now the people interested will have a holster that will protect and accomodate their kit.
Good luck with the sale  |
Replicant 13 Community Member
Posted: Thu Apr 18, 2013 7:43 pm Post subject: PROPER CREDIT |
I appreciate the credit, but it's Proper who's doing the work! I'm just thankful that he was so open to the suggestion. Just proves, it never hurts to ask . . .
Sad to say, I've damaged more than one replica (gingerly) trying to fit it into my Steinschneider holster. No doubt, like many here, I had resigned myself to the fact it could only be a companion display piece.
But now, thanks to Karl we all may have an accurate, but useable holster. - R13
(Hopefully this weekend I can attempt that casting, Karl). _________________
Posted: Fri Apr 19, 2013 1:27 am Post subject: |
It's kind of a metaphor for the community really. A good example of co-operation.
I don't collect resin blasters and so wouldn't automatically have identified the need for such a holster.
I think the willingness to listen is key here.
I'm actually surprised no one has done one like this before. I'll admit I had my doubts at the outset, largely about the ability of the holster to hold it's shape without the internal spring, and about just how 'soft' a grip I could get.
Both turned out to be unfounded.
There's a lot of work done in opening up the holster inside to make room for the bull nosed receiver and barrel end, and the result is the grip is ridiculously light.
Because the retainer strap snap is on the back and the strap is black-on-black across the magazine base, you don't really notice it.
I'm going to call this idea a success
Posted: Fri Apr 19, 2013 4:42 am Post subject: THE SPIRIT OF PROPSUMMIT |
Agreed! Again, that's what I love about this "place". Communication, interaction, cooperation, feedback and results - success!
The potential is almost limitless. - R13 _________________
