DaveG Community Member
Posted: Tue Jun 04, 2013 9:37 pm Post subject: |
I've not attempted to blue the zinc yet but one thing I know from blueing and chemically treating other metals is that you can get a lighter finish by diluteing the solution with water, sometime a lot. that way you can sneak up on the shade you want. _________________ Dave
Posted: Wed Jun 05, 2013 8:02 am Post subject: |
great idea dave. I wonder if you dilute a whole bottle of it in enough water so that you can dip the receiver in? This might give it a nicer even finish.
Looking at more pics on the tomen blog I saw that the receiver goes from jet black to the gun metal. I think they rub it down with fine sandpaper to get the lightness they want. I might order some black and do some tests on a sid bullet.
Also they seem to be using brushes. I'm not sure if they are brushing on the black. What are your thoughts on brushing this stuff on as opposed to using a sponge? Brushing will get into all the engraved areas too which is an advantage. _________________ "F*ck it, it's just a movie. Let him worry about it" Harrison Ford |
jontom Community Member
Posted: Wed Jun 05, 2013 12:46 pm Post subject: |
Hey Beast,
Could you post the link to that page of the blog?
Its a bit hard to navigate the Japanese.  |
colinfair Community Member
Posted: Wed Jun 05, 2013 1:33 pm Post subject: |
hey
jontom
mine came out the same as Jakob's, after three attempts not happy with it putting on taking off i gave up and left the last coat on and then covered lacquer.
i didn't know you could water it down now I'm mad
colin |
Posted: Wed Jun 05, 2013 1:37 pm Post subject: |
Maybe you can try polishing it? Can use some fine sandpaper or wirewool and a tiny bit of silver polish. Did you pretty much leave it the natural black after applying it? _________________ "F*ck it, it's just a movie. Let him worry about it" Harrison Ford |
Posted: Wed Jun 05, 2013 1:54 pm Post subject: |
Tomenosuke blog with thread on blaster...
http://tenshu53.exblog.jp/tags/%E7%95%99%E3%83%96%E3%83%A9PRO/
If you want to translate it, you can use google and or chrome as well as babelfish at yahoo.com to do so. I use chrome or the google toolbar on explorer, but just cutting and pasting the web address into google and then it will give you an option to translate the page. I must teach everybody googlefu.
Posted: Wed Jun 05, 2013 5:01 pm Post subject: |
Here is the page of the blog where they mention Aluminum Black. Interestingly, the bottle is the second photo is Casey's Super Blue.
http://tenshu53.exblog.jp/17775272/ |
Posted: Wed Jun 05, 2013 6:36 pm Post subject: |
TFS Andy and jontom  |
Posted: Thu Jun 06, 2013 9:53 am Post subject: |
I did some more poking around on the interwebs, its looks like this discussion comes up a lot on the modelgun forums, for people who have 1/1 scale replicas of actual firearms (German WWII SMGs, etc). This thread covers using Aluminum Black on a Colt 1911.
http://mp40modelguns.forumotion.net/t2452-blueing
Note that he also discusses the dilution method that DaveG talked about.
Quote: | I used Birchwood Aluminum Black (BAB)
For HW plastic or zinc, aluminum black makes more blue color where regular steel blue makes more black or very deep blue.
For bluing, I usually do "dipping" rather than "rubbing". For this 1911, I diluted BAB by 3 times. But, I think I should have done in 5 times or more. If you dilute less, sometime it is bit difficult to make a good come because a reaction of BAB is fast, easy to make uneven finish. Also, less diluted BAB makes oxidization last longer even after you finished bluing process. I heard many of voice one made success in good blue color, but couple days later, it turned to black color. Therefore, if you do "dipping", I suggest 5 times or more. For zinc parts, I suggest even more diluted liquited, maybe 10 times or more. Zinc parts are very difficult to retain nice blue color. Likewise in my 1911, it becomes black easily.
There are many ways, tips, do's and don'ts, my method is just a one sample. |
Posted: Thu Jun 06, 2013 11:35 am Post subject: |
great find! So maybe diluting is the key. I imagine that you polish the hell out of the metal get a really shiney finish and the BAB will darken it still retaining the polish? or would it require a little bit of an extra polish after? Also how long would one dip it in for and how long do you leave it to dry? Also I've seen bluing tutorials where they rinse the part straight after the dip under cold water. Is this also required? _________________ "F*ck it, it's just a movie. Let him worry about it" Harrison Ford |
Posted: Thu Jun 06, 2013 6:13 pm Post subject: |
My Aluminum Black and Perma Blue kit arrive next week, I hope to start experimenting with the Bulldog grip frame, and other pieces to get a feel for what this stuff does.
Gotta get to polishing! |
Posted: Fri Jun 07, 2013 4:54 pm Post subject: |
What can be used as a good decreasing agent? I'm thinking more along the lines of household stuff. I was thinking vinegar, though worried it might damage the zinc coating on the metal :S _________________ "F*ck it, it's just a movie. Let him worry about it" Harrison Ford |
Posted: Fri Jun 07, 2013 7:00 pm Post subject: |
rubbing alcohol, lighter fluid, acetone, methylated spirit, dish soap.....
Posted: Sun Jun 09, 2013 3:03 am Post subject: |
proper wrote: | rubbing alcohol, lighter fluid, acetone, methylated spirit, dish soap.....
Just be sure to wear gloves and a mask and/or be outside - most of the stuff above is easily absorbed into your skin and is very very bad for you - unless you're a fan of cancer. |
Posted: Mon Jun 10, 2013 8:05 am Post subject: |
Yeah i remember bluing for the first time, got the stuff all over my hands! Not good Safety always comes first. _________________ "F*ck it, it's just a movie. Let him worry about it" Harrison Ford |
Posted: Fri Jun 14, 2013 2:05 pm Post subject: |
this is how mine turned out, i think i will strip it down again happy not happy with it
also could someone please give me an idea of how to wire up the green leds, i connected the wires to one of the red leds and all i got was a dull green glow.
[img]
colin |
Ozwepaie Community Member
Posted: Fri Jun 14, 2013 2:35 pm Post subject: |
I'll post a photo later to show you how to do it.
However, I can't get it to "phase"on the way the red ones do.
& it's driving me nuts. But it is just as bright. & does not require any
additional power. Nor does it dim the red lights.
You will need a 3/4" or longer, thin attachment for your soldering iron.
The one point is pain to get to. _________________ Que la Force soit avec toi |
Posted: Fri Jun 14, 2013 3:42 pm Post subject: |
thanks
looking forward to seeing that, yes it would be nice to have them phase in like the reds.
i would have thought since they supplied the leds they would have at least shown how to wire them to the board
cheers
colin |
Posted: Sun Jun 16, 2013 1:50 pm Post subject: |
That's wishful thinking.
Anyway, here you go.
Posted: Sun Jun 16, 2013 7:06 pm Post subject: |
TFS with us Oz...looking good for sure  |
