Goldberg Arms' .38 Cal. Detective Special
Goto page 1, 2, 3  Next
DaveG
PostPosted: Sun Mar 31, 2013 12:08 pm    Post subject: Goldberg Arms' .38 Cal. Detective Special Reply with quote
AVAILABLE SOMEDAY
SIZE COMPARISON
Dave
PostPosted: Sun Mar 31, 2013 12:13 pm    Post subject: Reply with quote
In for one.
doppelganger01
PostPosted: Sun Mar 31, 2013 3:22 pm    Post subject: Reply with quote
Very nice design. It will look just as amazing as your snub design.
Rick
www.pflagerkatsumata.com
www.ricklross.com
PostPosted: Sun Mar 31, 2013 5:26 pm    Post subject: Reply with quote
Oh man Shocked This is looking good already...so much to buy
PostPosted: Mon Apr 01, 2013 12:51 am    Post subject: Reply with quote
PostPosted: Thu Apr 04, 2013 9:32 pm    Post subject: Reply with quote
That is VERY cool.
DaveG
PostPosted: Thu Apr 04, 2013 9:53 pm    Post subject: Reply with quote
So I'm trying to work on the computer model for the .38 Special but my cat had other ideas!
But she finally went to sleep. Blasters for her pillow.
Dave
PostPosted: Fri Apr 05, 2013 6:39 am    Post subject: Reply with quote
Carefull with those cats Dave: they're aliens trying to take on the world Confused
Joke apart, I can see that you've made some headway with that 3-D rendering...cannot wait to see the results, but also the build
DaveG
PostPosted: Fri Apr 05, 2013 10:29 pm    Post subject: Reply with quote
Working on refining the design of the .38 cal. Detective Special. The concept is that it is basically built on the same frame as the .38 cal Snub Nose but with a longer barrel, larger capacity ammo mag and a larger, full handed grip. this will allow the reuse of several of the same patterns from the Snubby. Plus additional accessories, like a suppressor or targeting system will fit both blasters.
The grip portion of the frame will be cast with openings as shown. They can be filled with weights to give the resin blaster a bit more mass, or left open for a look reminiscent of the hero blaster.
The kit will be cast in more parts, in particular the side covers will be separate castings from the frame. This will allow for a hollow opening in the fame underneath the covers for the addition of weights for resin castings, or to reduce weight in the case of a metal version. Though it's not yet shown, the Detective Special will include the LED sockets and switch in the clip, and there should be plenty of room for electronics.
Dave
Skin-Job
PostPosted: Sat Apr 06, 2013 2:54 am    Post subject: Reply with quote
looks amazing!
Karl
PostPosted: Sat Apr 06, 2013 7:43 am    Post subject: Reply with quote
Yes indeed Cool
darthwolf7
PostPosted: Sun Jun 30, 2013 9:25 pm    Post subject: Reply with quote
Wow!!!!!! Super cool! I would LOVE one of these!!! My girlfriend was drooling over it as well...if they ever go into production I would be very interested! Amazingly Cool Design!!!! Cheers!
seesinsilhouette
PostPosted: Sat Oct 19, 2013 11:28 am    Post subject: Reply with quote
How are things progressing with this fantastic project? Smile
DaveG
PostPosted: Sat Sep 20, 2014 11:06 pm    Post subject: Reply with quote
Well it's been awhile but it's time to drag this project back up to the front burner!
The receiver, clip housing and clip patterns are done and ready for 3D printing. The clip is set up for 5 LEDs. Wiring up a battery and circuit in there will be tight but it can be done!
Dave
Ruprekt
PostPosted: Sun Sep 21, 2014 12:10 am    Post subject: Reply with quote
Very cool! Put me down for at least one. Mind if I ask what software you used, and what printer? Very nice execution on the model.
DaveG
PostPosted: Sun Sep 21, 2014 9:44 am    Post subject: Reply with quote
I use Rhino for 3D modeling. Very powerfull and flexible software.
I have a 3D printer I built myself that uses a DLP projector to cure a photopolymer resin, very high resolution. I'll use it for the smaller parts. The larger part I'll send to Shapeways.
Dave
PostPosted: Sun Sep 21, 2014 6:51 pm    Post subject: Reply with quote
Looking mighty cool there Dave! Eager to see the next installment
DaveG
PostPosted: Sun Sep 21, 2014 10:59 pm    Post subject: Fun with the CNC Reply with quote
The pattern for the frame and block forms of the grips were milled out of 40 pound urethane foam on my CNC router. I'll finish up the shape of the grips the old fashioned analog way... with files, rasps and sandpaper.
Dave
stonedog7563
PostPosted: Mon Sep 22, 2014 10:19 am    Post subject: Reply with quote
Top class work, would love one but the powers that be wont allow it Mad
Ruprekt
PostPosted: Mon Sep 22, 2014 3:04 pm    Post subject: Reply with quote
Have it shipped in pieces. That should work, no?
Page 1 of 3
