‘Give me about twenty minutes’ – ALIEN – Incinerator Unit
Goto page Previous  1, 2, 3 ... 8, 9, 10 ... 13, 14, 15  Next
PostPosted: Wed Dec 24, 2014 5:12 pm    Post subject: Reply with quote
Thanks (Tony) ukwookie that will be helpful.
I'll look for a few more higher rez images on the web for a comparison.
Colin
Ripley: What's it key on?
PostPosted: Sun Dec 28, 2014 4:19 pm    Post subject: Reply with quote
Yep, Tony is right Colin; mainly Airfix models were used by our U.K. model maker friends Wink
PostPosted: Thu Feb 26, 2015 2:54 pm    Post subject: Reply with quote
Here's a small update on the flamethrower.
I had chance to turn the rest of the pipe detail on the right hand side.
I'm reasonably happy with it. Just needs a bit of tweaking and then moulding and casting as one piece.
I hope to get back on with the build more seriously soon and I will post updates.
Hopefully it should start coming together as a finished piece over the next few months!
Colin
PostPosted: Thu Feb 26, 2015 5:01 pm    Post subject: Reply with quote
The piping sure looks sharp Colin...eager to see the next update Wink
PostPosted: Fri Feb 27, 2015 5:13 am    Post subject: Reply with quote
Joberg, the shapness is the thing I'm thinking of changeing. I may go in a bit deeper with the grooves and then round off the edges.
Colin
PostPosted: Sat Feb 28, 2015 8:37 am    Post subject: Reply with quote
Do you think that could keep what you have already and simply put a small bevel on the edges. It could "open" your grooves Wink
PostPosted: Sat Feb 28, 2015 1:47 pm    Post subject: Reply with quote
yes joberg my plan is to keep it pretty much as it stands now. I was only planing on making the grooves fractionally bigger. Maybe I'll try a needle file first.
Colin
PostPosted: Sat Feb 28, 2015 10:39 pm    Post subject: Reply with quote
Ah, o.k. got it
LadyVengeance
PostPosted: Tue Mar 03, 2015 9:16 am    Post subject: Reply with quote
This looks amazing! Shocked
PostPosted: Tue Mar 03, 2015 4:27 pm    Post subject: Reply with quote
Thank you LadyVengeance.
Colin
PostPosted: Tue Mar 03, 2015 5:38 pm    Post subject: Reply with quote
Welcome aboard LadyVengeance
PostPosted: Sun Mar 15, 2015 1:37 pm    Post subject: Reply with quote
I did the adjustments on the turned pipe. I took joberg's suggestion and mostly used a needle file to open up the slots. Worked a treat.
Using my trusty Lego I made a one piece mould.
I cut the mould on the underside, so the seam will not be visible when it gets attached to the body.
I then bent up some 1/8th inch steel rod, to suspend in the mould, to give the piece a bit of extra strength.
The casting came out nice and clean.
This week I started working on the dummy white tank. Because I need a hole all the way through I decided to make the pattern in sections so I could drill a hole through each section comfortably.
The top section still needs its hole drilling.
Here's a comparison to my real tank.
I plan on doing a two part glass fibre mould. A piece of hexagonal steel will run through the center of the tank to take the fittings at either end. The final cast will be glass fibre.
Colin
PostPosted: Sun Mar 15, 2015 6:45 pm    Post subject: Reply with quote
Glad I was of help Colin Love the pipe! As for your tank, doing it like this will surely reduce the weight of that baby Wink
PostPosted: Mon Mar 23, 2015 2:47 pm    Post subject: Reply with quote
Spent some time last week sorting out some smaller jobs on the flamethrower.
I decided to remake the small detail piece which hooks over one of the Hornby Piers on the right side. The perspex one I had 'pinged' off due to insufficient gluing surface.
I made it again but this time put a web across the base. Rather than gluing on the new perspex one, I moulded it and stuck a fast cast one on. It's still fragile but feels better!
You can see the fast cast one in the second picture.
I filled the semi circular cut out on the right side and blended it into my routed edge. Also I drilled the exit hole for the propane pilot flame feed.
Then using some EMA I sketched in the pipe which runs on the forward lower right side.
A wider shot.
Here's an internal shot showing the polyurethane pipe connecting to the propane bottle. I shortened the turned brass connector I made and notched out the back of the trigger housing for a better fit.
I've drawn up some plans for the 'Nostromo Antenna' detail mounted on the left side. I'm making it in sections, these will slide onto a steel rod.
I've done some similar drawings for the pipe on the lower right side too. So these should start coming toghether in the next few weeks.
I got my hexagonal steel bar today to mount in the dummy tank. So I hope to get that cut to size, drilled and tapped this week. Then I will finally be able to hang two tanks off the unit.
The hex bar is quite heavy so I dont think it will be too light. I can always ad some ballast into the glass fibre tank.
Colin
PostPosted: Mon Mar 23, 2015 5:03 pm    Post subject: Reply with quote
Great update Colin...eager to see that baby in all its beauty Cool
PostPosted: Tue Mar 24, 2015 3:33 pm    Post subject: Reply with quote
BRILLANT WORK as always, Colin !!!
PostPosted: Sun Apr 05, 2015 4:45 pm    Post subject: Reply with quote
Just a quick update.
I drilled and tapped the hex steel to run thru the dummy tank.
Here are a couple of pictures with the fittings screwed on and the tanks in place.
I still have a bit of alteration to do to the hex bar before I blend the tank together and mould it.
Colin
PostPosted: Tue Apr 28, 2015 1:49 am    Post subject: Reply with quote
wow wow WOW !
Well done Colin !
PostPosted: Tue Apr 28, 2015 7:56 am    Post subject: Reply with quote
Thank you, Fred.
Page 9 of 15
