Posted: Mon May 23, 2016 3:26 pm Post subject: |
Those measurements are from a finished housing  |
Posted: Tue May 24, 2016 8:59 am Post subject: |
Perfect, thanks Joberg... I think that could work, perhaps the correlation between the screen and housing will be a little off, I'll have to wait and see
| joberg wrote: | Those measurements are from a finished housing  |
Posted: Fri Jun 03, 2016 4:06 pm Post subject: |
Any ideas for the source of the metal wheels on the arm?
OR clever ideas for metal alternatives?
Posted: Sat Jun 04, 2016 9:44 am Post subject: |
I reproduced the wheels myself on mine. The only mistake I made was that the rear wheel (the one close to the box and not the eye) is that it's half metal (the groove holding the cable) and half plastic. You could always look at Stephen Dane's pics, it's very detailed.
Or you could try to turn those in metal (alu) by one of our member? |
Posted: Sat Jun 04, 2016 10:26 am Post subject: |
Ahh! So the rear could theoretically just be 3 discs put together?? That would make it easier...
Hmm, when I get the correct measurements down, getting them machined on a lathe would be awesome! Great idea! Think I will l
By the way: New main display with better dimensions!
https://www.youtube.com/watch?v=eINgbutHy1A _________________ Monsieur, azonnal kövessen engem bitte
Robotprops Community Member
Posted: Sun Jun 05, 2016 1:22 am Post subject: |
| They look like they could be camera mount hand wheels. You can get them in many looks but only a couple standardized sizes. You would find them on tripod mounts and flash attachments etc... |
Posted: Sun Jun 05, 2016 5:44 pm Post subject: |
I wouldn't go that far Anders. A simple alu-wheel with a plastic cover would do. Did you see the Stephen Dane vid?
Video of the eye is the bomb btw  |
nickdaring Community Member
Posted: Wed Jun 08, 2016 1:17 pm Post subject: |
| What size screen are you using for the main display? |
Posted: Wed Jun 15, 2016 10:02 am Post subject: |
| nickdaring wrote: | | What size screen are you using for the main display? |
It's a 7" display. A bit on the large side, but with more accurate dimensions (NOT widescreen). I'm aiming for the this front, which justifies the larger main display:
Posted: Wed Jun 15, 2016 10:04 am Post subject: |
| Robotprops wrote: | | They look like they could be camera mount hand wheels. You can get them in many looks but only a couple standardized sizes. You would find them on tripod mounts and flash attachments etc... |
Cool.. will look into that! Thanks  _________________ Monsieur, azonnal kövessen engem bitte |
Posted: Thu Jun 16, 2016 12:53 pm Post subject: |
The wheels look like belt wheels from a VCR or tape recorder. Even similar to ones on a turn table.
Posted: Wed Jun 22, 2016 1:58 am Post subject: |
I've been keeping my eyes open at work for this type of thing.
I've seen a few types on camera and grip related equipment as well as on lamps. Desk lamps to be specific.
The first one is from an offset camera mount for a dolly.
Second is tightening wheels for the matte box.
Third is a lamp. The brand is stamped on the arm.
I think the lamp option is closest to the VK. Considering how many lamps and lamp parts were available to the prop builders, it would seem likely that they borrowed a few parts back and forth.
Flash mounts and tripod mounts have similar wheels that are cheap and worth looking in to.
Posted: Wed Jun 22, 2016 7:05 pm Post subject: |
TFS Robotprops...or it could be to slim round slim pieces put together and held by a central screw/hub  |
Posted: Fri Oct 28, 2016 10:32 am Post subject: |
| BC-RX on therpf has posted a vid showing parts of the Ridley Scott Exhibition in Nothern England. In the first few seconds, you can see a V.K. machine on display. Seems to me that it's not the screen-used one (L.A. shoot) nor the one they re-shot in the U.K. with transformed screen (which is suppose to be in SRS London office)...Thoughts? |
Posted: Fri Oct 28, 2016 12:44 pm Post subject: |
Had it been the real one on display, I would have been on a plane right now...
Looking at that video.... hehehe.... oh my....
Thanks for sharing! _________________ Monsieur, azonnal kövessen engem bitte |
Posted: Sun Oct 30, 2016 9:16 am Post subject: |
Mine looked much closer to the original  |
