Blade Runner Blaster Comparison. Add your pics...
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Sun Jul 15, 2007 1:45 am    Post subject: Reply with quote
Good to have you here Serafino. Nice comparison pic too. Hope you come back after "passing through".
Eagle
PostPosted: Mon Aug 20, 2007 12:58 pm    Post subject: Reply with quote
Anyone know the release date for the Worldcon SidKit? Smile
amish
PostPosted: Mon Aug 20, 2007 1:32 pm    Post subject: Reply with quote
I just shot him an email and hopefully he will reply or post here.
www.propsummit.com
www.bladerunnerprops.com
PostPosted: Wed Sep 12, 2007 7:53 am    Post subject: Reply with quote
does anyone know how you'd wire up the green LEDs using just the two single wires shown in the worldcon gun pic?
Do the green LEDs on Rich' model light up?
PostPosted: Wed Sep 12, 2007 8:13 am    Post subject: Reply with quote
Yes the green LEDs light up on my model and there is two PAIRs of wires shown on the Worldcon Blaster.
PostPosted: Wed Sep 12, 2007 5:46 pm    Post subject: Reply with quote
ah yes I can see two pairs now, thanks for pointing that out. So I assume you had to drill or hollow out the whole laser site to get these in then? do the green LEDs share the same switch as the red ones?
Also does anybody know where to get the round LED holder things?
PostPosted: Wed Sep 12, 2007 5:50 pm    Post subject: Reply with quote
Your welcome and yes I cast a hollow tube in the side rod.
And yes mine turn on with the same switch used for the red ones.
Try a electronics supplier like Mouser.
Eagle
PostPosted: Sun Sep 23, 2007 1:53 pm    Post subject: Re: my hero blaster Reply with quote
IGNITERS wrote:
How do you get that colour and finish on the barrel etc? It's spot-on. Smile
IGNITERS
PostPosted: Mon Sep 24, 2007 12:39 pm    Post subject: color and finish .... Reply with quote
I may have posted a better explanation somewhere on this site , but the simple version is gun blue, black shoe polish,a lot or tiny pin jabs for the rusting corrosion,brown rust color emamel paint dabbed on with a coarse scouring pad more blue and polish etc.....the sidkit metal did most of the work ,blue helps alot though...the polish helps the blue stay black and takes away the chalky finish....hope this helps!
Eagle
PostPosted: Mon Sep 24, 2007 12:49 pm    Post subject: Reply with quote
Thanks for the tips. I'm going to experiment. Smile
IGNITERS
PostPosted: Mon Sep 24, 2007 1:11 pm    Post subject: tips ... Reply with quote
no problem ,GOOD LUCK AND HAPPY RECREATING!
Kgaijin
PostPosted: Wed Oct 10, 2007 3:53 pm    Post subject: Reply with quote
I am working on my Sidkit metal blaster and I have noticed that some people have melted down some of the included bullets. How hot does the metal need to get? Will one of those mini torches do?
PostPosted: Thu Oct 11, 2007 2:31 am    Post subject: Reply with quote
Nice work Igniters!
The color selection looks fantastic on yours. You can see tho how undersized the grip is. In my photo the grip FILLS my hand... the back strap is on my palm, and my fingers curl tight around the cutouts in front. Yet my hand fits comfortably and my three fingers are entirely below the trigger guard and above the buttplate.
Here's a parting "replicant's eye view" for y'all.
Eagle
PostPosted: Thu Oct 11, 2007 2:17 pm    Post subject: Reply with quote
The CS&T WorldCon.
Seems this thread needs it. Smile
A work of art, IMO.
the DOCTOR
PostPosted: Fri Oct 12, 2007 2:16 pm    Post subject: Reply with quote
I just used a heavy duty (mains) soldering iron- so a mini blowtorch should be more than adequate!
Once-bitten
Banned!
PostPosted: Fri Oct 12, 2007 7:40 pm    Post subject: Reply with quote
I used a steele ladel on top of a hot-plate coil...certain it didn't get any hotter than 400 degree's. When I wanted to rush the whole process I used a small butane torch which worked very nicely.
The bullets were NOT the only part that got put into the melting pot from my
Sid-Kit!
Kgaijin
PostPosted: Fri Oct 12, 2007 7:48 pm    Post subject: Reply with quote
Thanks guys, just what I needed to know. I am not building my kit to exact "Worldcon" specs, but I am replacing the molded screws and such. Trying to get it done by halloween.
Once-bitten
Banned!
PostPosted: Fri Oct 12, 2007 8:00 pm    Post subject: Reply with quote
Good luck!
Don't forget to post some pics when you finish!
CENOBITE
PostPosted: Sun Dec 30, 2007 7:33 am    Post subject: Reply with quote
Whoa, whoa... whoa....
OK. So what is this 'Worldcon' gun everyone is talking about here? I can only guess that it is named the worldcon as it was only sold at a convention called worldcon, or is a replica of the original br gun shown at worldcon.
So quesiton is... how do you go about GETTING one... or better yet... where do you go to get any of these and what prices are we looking at?
Now that the 'official' BR gun has been located and shown, any plans on NEW and ACCURATE props being produced for the masses?
PostPosted: Sun Dec 30, 2007 7:58 am    Post subject: Reply with quote
The worldcon blaster is based on the hero prop that was on display at worldcon. Hit up a few of the blaster threads around here and you'll get the skinny pretty fast on it. The one shown in Eagle's photos is the worldcon version that Rich makes. I don't own that particular one myself but I do own a couple of Rich's blasters its the closest you get to the real deal short of building up your own out of original parts.
Far as I know, there are no plans to mass produce these. The Offworld 2019 model is the only mass produced one I know of, and it takes a bit of work to get it looking good out of the box.
Welcome to the boards btw.
Page 3 of 8
