Talyn Community Member
.gif)
Posted: Sat Oct 21, 2017 1:58 pm Post subject: Takagi Mod - Custom Gaff "Dandy" Blaster |
Finally calling this done. Went back and forth on the brass screws on the grips because they are a departure from anything used on the original, but I thought they went well with the pearl. All of the LEDs are just glued on. The piece on the front of the receiver was from the inside of a small faucet filter.
I removed and molded the original grips and then made pearl castings. I filled the entire blaster with resin and filled out the grip frame for the new grips to glue onto. I used the orange tip cap as a barrel extension. Everything was aged with various weathering powders, which is what gives the receiver that slight brown hue.
There are only a few added greeblies here and there, but it’s really amazing what can be done with this squirt gun.
 _________________ RPF: Kylash
Posted: Sat Oct 21, 2017 4:58 pm Post subject: |
Thats fantastic, great job. Very Gaff.
How the hell did you get the grips to look like that? _________________ Formerly offworld66 |
.gif)
Posted: Sat Oct 21, 2017 6:58 pm Post subject: |
Thanks, I made molds of the toy grips and cast them with clear resin with pearlEx powder mixed in, which gives the metallic swirls look and leaves some translucency. _________________ RPF: Kylash |
rickhoward Community Guide
Joined: 03 Jul 2016 Posts: 290 Location: Midwestopia, USA
Posted: Sat Oct 21, 2017 7:36 pm Post subject: |
| Fun stuff. Thanks for sharing. |
Posted: Sun Oct 22, 2017 10:38 am Post subject: |
Fun stuff indeed and those grips look a lot like the real one veekthor got from the Propstore  |
.gif)
Posted: Mon Oct 23, 2017 4:42 pm Post subject: |
Thanks guys. I just figured I should make it a custom blaster since the stamping on the top isnt accurate anyway. If i were to have made Deckard's out of it, that wrong stamping would bug me, so i went this route, which could plausibly have different stamping (and be made in China).
| joberg wrote: | Fun stuff indeed and those grips look a lot like the real one veekthor got from the Propstore  |
That was partially where I got the idea, if it was almost what Deckard's had, its good enough for me! _________________ RPF: Kylash |
veektohr Community Member
Posted: Mon Oct 23, 2017 7:10 pm Post subject: |
| This turned out awesome. That pearl finish is smack on for the test pair! |
EJ_Watts
Posted: Tue Nov 14, 2017 8:36 pm Post subject: |
| Great work! I particularly like the unique look with those great grips. I've been working on a squirtgun mod as well, tell me - were you able to keep the triggers movable, or did the resin seize them up? |
.gif)
Posted: Thu Dec 07, 2017 4:37 pm Post subject: |
I made them fixed, filling with resin complicated that a bit and it just made it easier. _________________ RPF: Kylash |
ogrotesque1 Community Member
Posted: Wed Jan 03, 2018 5:10 pm Post subject: |
I’m diggin’ this! Nice work, very nice work.... _________________ Damion: ogrotesque1 |
