MarcusKirsch Community Member
Posted: Tue Nov 21, 2017 8:42 am Post subject: |
Way too little progress, but the sizes better be good to perfect as the electronics to be fit inside will be quite a challenge.
Posted: Tue Nov 21, 2017 8:43 am Post subject: Doubel screen housing |
Very slow process, but it better be good to perfect as I need to fit heaps of electronics into my version.
Posted: Tue Nov 21, 2017 8:48 am Post subject: |
.... nearly there ... |
Posted: Wed Nov 22, 2017 7:30 pm Post subject: |
What's the size of that box LBM? |
Posted: Thu Nov 23, 2017 9:25 am Post subject: |
LBM? or are you asking me? I just resized mine to 112x128x46mm + about a 4mm gap between double screen box and the main casing. |
Posted: Thu Nov 23, 2017 11:50 am Post subject: |
Sorry, Marcus...asking you and thanks for the answer  |
Posted: Thu Nov 23, 2017 5:07 pm Post subject: |
BTW is this one of the real props?
LearnByMaking Community Member
Joined: 31 Jan 2017 Posts: 63 Location: USA, Illinois
Posted: Thu Nov 23, 2017 11:34 pm Post subject: |
As I recall this is a picture of the US/Mike Fink original. It was posted (by nickdaring) on page 4 of the Voight Kampff Reference Photo's thread and came from Steve Danes's "Moments in Design" - https://vimeo.com/69335540 _________________ If only you could see the things I've seen with your eyes. |
Posted: Fri Nov 24, 2017 7:47 am Post subject: |
Yes, it's the real Mike Fink & Co prop. By the look of what's around the prop (for example the folder at the upper right hand side corner of the pic) it would be fairly easy to come up with measurements.
Now the question is: regular folder is 11 and 3/4 inches...is this a regular folder? |
Posted: Tue Nov 28, 2017 3:30 pm Post subject: |
So I thought I design something where I can more easily fix the CRTs if needed. Removable top box.
Posted: Tue Nov 28, 2017 7:12 pm Post subject: |
Difficult to have a nice seal on top of those boxes...that's why the entire housing is removable ( exposing the innards ).
The small screens do not protrude from their housing (flush with it)...it's even possible to have the cables (bottom right hand side, facing the front of the machine) removed in one swoop (they should, then, be attached together of course)
Posted: Tue Dec 05, 2017 5:43 pm Post subject: |
Double solution better size and cardboard. |
