Sarednab Community Member
Posted: Fri Dec 22, 2017 12:07 am Post subject: |
Fangorn81 wrote: | My bottle seems to be floating in some ether between Milan and the US...
ugh. |
Christmas time, you must be patience |
Barrels Community Member
Posted: Fri Dec 22, 2017 6:04 am Post subject: |
Received the bootle a few days ago. Great packaging. Thanks for the fantastic work. |
Fangorn81 Community Member
Joined: 03 May 2009 Posts: 168 Location: Brooklyn, NY
Posted: Fri Dec 22, 2017 11:23 am Post subject: |
Sarednab wrote: | Fangorn81 wrote: | My bottle seems to be floating in some ether between Milan and the US...
ugh. |
I know! Just anxious! _________________ Good against remotes is one thing. Good against the living? That's something else.
Joah Mahan |
Posted: Sat Dec 30, 2017 2:34 pm Post subject: |
Glorious!
Added my own Finlandia lid (had to do some heat gun resizing).
Joah Mahan |
Posted: Sun Dec 31, 2017 5:11 am Post subject: |
This bottle is fantastic! Great job on this Sarednab. I replaced the cap with a more screen accurate one I already had. Will post some pics when it's all come together. _________________ "F*ck it, it's just a movie. Let him worry about it" Harrison Ford |
Posted: Sun Dec 31, 2017 8:58 am Post subject: |
BeastMaster wrote: | This bottle is fantastic! Great job on this Sarednab. I replaced the cap with a more screen accurate one I already had. Will post some pics when it's all come together. |
Many thanks mate  |
fightercaptured Community Member
Posted: Tue Jan 02, 2018 10:13 am Post subject: |
@Fanghorn81 that cap looks great! Did you just heat it up a bit so it would fit over the lip of the bottle? Also, is that from a 750ml? |
Posted: Tue Jan 02, 2018 4:51 pm Post subject: |
fightercaptured wrote: | @Fanghorn81 that cap looks great! Did you just heat it up a bit so it would fit over the lip of the bottle? Also, is that from a 750ml? |
Yeah. Was a bit nervous about it, but it was fine. Had to use needle nose pliers to rip out the inner threaded part of the cap first, then heated and press-fit it onto the bottle. There is a little bit of crazing in the faux metal finish on the cap, but it is so fine that it looks like a brushed finish.
Also, its a very nice water-tight fit. So far it hasn't leaked or anything (and there isn't a cork).
it's from their smallest bottle ($12 here in NY). The Finlandia lids are all the same size. The lady at the liquor store let me look at and compare the lids on all of them to a lid I brought with me...
She didn't even look at me like I was crazy. _________________ Good against remotes is one thing. Good against the living? That's something else.
Joah Mahan |
TomVDJ Community Member
Posted: Wed Jan 03, 2018 5:19 pm Post subject: |
Finlandia vodka! Great tip for the cap. They sell that stuff over here too, so I might give that one a try. Is de vodka itself any good? (Not going to waste the vodka itself, off course ). |
mik Community Member
Posted: Fri Jan 19, 2018 3:57 pm Post subject: |
Mine cane in a couple of days ago and it is superb. Took a while but the packaging was top notch and it is safe and sound. |
Bugen Community Member
Posted: Sat Jan 27, 2018 8:57 am Post subject: |
So I finally managed to spend some time with my beautiful new bottle but have a couple of issues, I just wanted to make a quick post to see how other people have found their bottles and get some comparison to mine:
1) My bottle has a slight wobble to it, to the point where I feel I have to be careful putting it down. It certainly doesn't still 100% well and I am able to rock it whilst it is standing up straight on a flat surface.
2) One of the 'shoulders' has a not-insignificant mark on it and is sadly in a fairly prominent location, pic attached below. I fully understand given the nature of it's construction there were going to be marks on the glass etc. but I wondered if anyone has something similar or might I have been given an incorrect bottle by mistake?
This is certainly not a criticism of you Sarednab, you've done incredible work here and I was so excited to receive this, I just want to temper my expectations with what others have found and I know that you care deeply about the quality of your work. After having waited almost a decade to be able to afford one I want it to be right!
Many thanks from Bugen.
Posted: Sat Jan 27, 2018 9:21 am Post subject: |
No mate, all “light” imoerfection was due cause it is all handmade. All bottles have something |
