Silverside Community Member
Posted: Sat May 12, 2018 2:38 pm Post subject: |
I see one of the boxes from this first run has just been listed on ebay, in Australia, for $1,250. That’s a real mark-up! |
Joined: 05 Mar 2007 Posts: 899 Location: London, England
Posted: Sat May 12, 2018 3:31 pm Post subject: |
I know I should have charged more
K |
Posted: Sat May 12, 2018 3:32 pm Post subject: |
Silverside wrote: | I see one of the boxes from this first run has just been listed on ebay, in Australia, for $1,250. That’s a real mark-up! |
Listed for about US$520 - start bid price. |
eethan Community Member
Posted: Mon May 14, 2018 7:09 am Post subject: |
just a question, the glue products you are recommending are the same you already used or they are different and should work better?
if they are the same, chances are that the problem will appear again in a while. If it didn't happen for every box, I guess it might depend on the place we live or something. I mean, I haven't touched that box for a while and when you posted that, I opened it and it was completely wobbly and unglued, I guess something happened because of the heat or something like that.
thanks |
Posted: Mon May 14, 2018 8:04 am Post subject: |
Hi Eethan,
I've used the manufacturer recommended glue on this material combination for decades with no problems.
I suspect they changed the formlation recently. I don't think it has anything to do with heat or location, etc.
That said, the test samples I made before the run are still glued fine. I don't know why.
The glues I've suggested, Evo Stik and Thixofix, are different from the original glue and should certainly fix the issue.
The reason I didn't use them on the run is that they are solvent heavy and smell strongly. But if you use them and then leave the box open for a few days, it should be OK. |
Posted: Mon May 14, 2018 12:07 pm Post subject: |
ok thanks.
are we sure the solvent based glue will not disolve the foam? I was surprised to read that when you wrote solvent but I'm no expert on that. |
Posted: Mon May 14, 2018 4:36 pm Post subject: |
Most glues are solvent based. The glue that didn't work perfectly is solvent based.
The suggested glues won't dissolve the foam into a mess.
I suggest that you coat both surfaces to be bonded, then wait until touch dry before pressing firmly but gently together.
K |
Posted: Tue May 15, 2018 7:40 am Post subject: |
ok thanks |
AnXo
Joined: 01 Feb 2018 Posts: 7 Location: A Coruña - Spain
Posted: Wed May 16, 2018 1:59 pm Post subject: Received :-) |
Hi Karl.
Just to let you know than I receive my box.
It is an amazing piece of work... I really love it.
100% recommended from my side to everyone
Thanks and maybe I will ping you back to check for a holster if you are still doing them
Again thanks both to Deborah and you.
Cheers.
AnXo. _________________ Anxo |
Posted: Wed May 16, 2018 3:30 pm Post subject: |
Hi Anxo,
Thank you very much.
I'm always happy when the work is appreciated.
Best,
Nexus7 Community Member
Posted: Sun Dec 09, 2018 10:58 am Post subject: |
Deleted
Posted: Mon Dec 10, 2018 3:19 am Post subject: |
Deleted |
Posted: Mon Dec 10, 2018 1:22 pm Post subject: |
Is there a US glue that is recommended for the foam? Thanks |
Posted: Mon Dec 10, 2018 4:11 pm Post subject: |
Any rubber based contact adhesive will be fine.
K |
