Design Thread: Nostromo interiors and deck configurations
Goto page Previous  1, 2, 3 ... , 25, 26, 27  Next
Vader
PostPosted: Tue Oct 17, 2017 12:44 pm    Post subject: Reply with quote
Here is my latest edition. Little tweaks here and there still to do; then I'll be about done, I think.
After that, one can start going crazy with the detailing ... but that might be a task for someone with a bit more time to spare, not to mention the proper software (I've done all of these in PowerPoint)...
Enjoy!
jkruse05
PostPosted: Tue Oct 17, 2017 10:58 pm    Post subject: Reply with quote
These look excellent. Personally, I still imagine the observation deck to be present just above the bridge, but that's more personal preference than anything. I think the next step is probably figuring out which rooms have ventilation access and where those vents travel.
PostPosted: Wed Oct 18, 2017 6:40 pm    Post subject: Reply with quote
That's looking very good Vader Cool
PostPosted: Fri Oct 20, 2017 2:08 am    Post subject: Reply with quote
Impressive effort to determine the Nostromo inner spaces !
Some very cool ideas here !!!
Vader
PostPosted: Fri Oct 20, 2017 5:23 am    Post subject: Reply with quote
I agree. I already have a fairly shrewd notion of where some of those ducts need to run, and approximately where the "3rd junction" ought to be located ... but more information is needed before that part of the puzzle can be solved.
Have you -- or anybody else here -- made any effort to map what we do know, which basically is the sequence of turns Dallas makes in the ducts?
Has anyone seen any production information on this -- set drawings, that sort of thing?
FenGiddel
PostPosted: Wed Nov 01, 2017 6:50 pm    Post subject: Reply with quote
I've been searching for any kind of information about the "vents" Dallas crawled through. Apparently a sparsely documented piece of the film... ;(
Oh! And I am enjoying seeing your ideas for the outboard engine nacelles.
FenGiddel
PostPosted: Sun Nov 05, 2017 8:52 am    Post subject: Reply with quote
Doing some thinking about the nacelle internals and sketched this to get me started. I based the thrust angles on the angles of the lifter nozzles, albeit roughly.
Vader: your nacelle interiors have taken into account spaces for the internal machinery, which is what got me thinking about this in new ways.
Graham: I am not sure what you are doing with (or can say about) your blueprints book drawings, but it would be cool to see a bit of the nacelles.
Starrigger: when you designed your "landing gear deploying" video, did you have any thoughts about the spatial relationship of the gear/bays to the nacelle's internal ducting?
Due to the size of the nacelles, it would seem they might be self-contained and somewhat independent of the main power unit that energizes the ship and the hyperdrive generating equipment.
If so, perhaps the tankage to provide fuel for the lifters' operation provide limited use, determined by the ship's flight profile for the voyage.
This provides an interesting plot 'engine' for stories involving CTVs going off-mission to investigate unexplained signals from uncharted planetoids: maybe life support is not the only thing that is counted in units of "time spent out of hypersleep"?
Just a few thoughts...
FenGiddel
PostPosted: Sat Apr 21, 2018 4:24 pm    Post subject: Reply with quote
Starrigger & Vader:
Take a look at what Danny Attree has done, relative to the giant navigation lights, with his Halcyon Nostromo kit:
https://thenostromofiles.com/2018/04/21/danny-attrees-halcyon-nostromo-model-with-navigation-lights/
Very near, indeed, to what you guys have drawn.
PostPosted: Mon Apr 23, 2018 6:01 pm    Post subject: Reply with quote
Very nice effect/work! He's really capturing the look Cool
mrseudo
PostPosted: Tue Nov 05, 2019 6:46 pm    Post subject: Bulkheads & Companionways Reply with quote
Hi guys! I've been checking out this topic for a few years and I wanted to ask about your thoughts on how the fictional engineers would have maintained pressure between the companionways. In ship design (submarine/spacecraft), the bulkheads partition pressurized areas of the ship. It would seem always-open companionways would be a vulnerability in the event of a hull breach or other decompression.
mrseudo
PostPosted: Wed Nov 06, 2019 12:36 am    Post subject: Lifts to A-Deck Reply with quote
I also wanted to follow up to a post submitted by Space Jockey some time ago... a LONG time ago regarding freight lifts to A-Deck. Based on the sound stage layout, there could be some options stemming from the center companionway junction. In the first scenes of the ship, you can view the back wall of the companionway across through the galley—it does not continue straight. (See the green line-of-sight in the diagram below.)
You can also see the ladder in the same companionway after Ripley fights with Lambert in front of the infirmary. This junction could allow two corridors to branch off at 45°, I assume, without conflict from the film. To me, it would be reasonable to have other useful areas of A-Deck other than the sound stage portion.
Another idea from Space Jockey which I LOVE is the locker room area branching at 45° from the freezers corridor. It totally makes sense there, unlike where it's located on the Torrens (Alien Isolation).
[/quote]
mrseudo
PostPosted: Sat Nov 09, 2019 12:45 am    Post subject: Reply with quote
On closer inspection, I noticed my first layout wouldn't work with the sound stage layout. Again, the scene where Ripley joins the crew in front of the infirmary, you can see the diagonal wall in the companionway. This would prevent a starboard-side corridor in that companionway. The only option would be a port-diagonal leading to a lift or something else. It makes sense in a way, since very little on this ship is symmetrical, other than the general fuselage.
FenGiddel
PostPosted: Sat Jan 02, 2021 9:06 pm    Post subject: Reply with quote
Nice work, mrseudo! Your graphics are clean, crisp, and illustrate your point very well. Good catch, regarding that portion of wall we see in the scene.
Have you any thoughts about how large the elevator/lift might be to serve the needs of a space-truckin' crew?
mrseudo
PostPosted: Tue Jan 05, 2021 10:37 pm    Post subject: Reply with quote
I'm glad this thread isn't dead yet!
Every large seafaring vessel on which I have either sailed or toured, has had some sort of lift. Since there isn't any real consensus about a gangway for the Nostromo, it would be sensible for there to be a way to move injured persons down to the airlock or possibly to the shuttle.
On that note, what logical challenge would there be for the umbilicus to also serve as a gangway?
FenGiddel
PostPosted: Thu Jan 07, 2021 3:01 pm    Post subject: Reply with quote
Very Happy
I agree that there are lots of cool details that a ship like Nostromo would possess but were not depicted on-screen. Imagining those very details is the source of my enjoyment of the ship.
That being said, your "umbilicus-gangway" idea is interesting. How do you imagine it?
mrseudo
PostPosted: Tue Jan 19, 2021 9:31 pm    Post subject: Umbilicus Gangway Reply with quote
FenGiddel
PostPosted: Tue Jan 19, 2021 10:26 pm    Post subject: Reply with quote
Interesting. So once the ship reaches home base and detaches the refinery, she'd next connect with a docking clamp that contains access for the exchange of personnel and/or equipment?
PostPosted: Wed Jan 20, 2021 10:21 am    Post subject: Reply with quote
Interesting idea for sure. It could make sense Wink
mrseudo
PostPosted: Wed Jan 20, 2021 11:57 pm    Post subject: Reply with quote
As we've seen with just about every attempt to land on bodies in space, there is considerable risk involved. A ship the size of Nostromo would be a colossal disaster if it broke up in the Earth's atmosphere (not to mention a reactor supernova). The landing in the film is certainly less than perfect.
I imagine the Nostromo engaging with an orbiting "garage" platform and having a personnel exchange there. The crew could then return to Earth on a shuttle or transfer to another orbiting vessel via Narcissus.
The umbilical crown would need to be a standard attachment point for all fleet vehicles. Towable units, like the refinery, would need a standard umbilicus to match it.
FenGiddel
PostPosted: Sun Jan 30, 2022 5:31 pm    Post subject: Reply with quote
Yes, over the years I've come to think that landings were rare for the ol' Nostromo and her type, for some of the reasons you've put forward. The single shuttle then becomes less an escape pod and more a transport for crew transfers. Tugs maybe then just got shifted around between refinery platforms in some gigantic yard space in orbit. Or maybe even stayed engaged to the same platform, making multiples runs as Dallas mentioned in on-screen dialogue. Makes the contract stipulated investigations all the more interesting given the potential cost in old ships making landfalls they're too old for.
Page 26 of 27
