Any Advice on Instructions Please?
Hoggydo
PostPosted: Wed May 06, 2009 12:41 pm    Post subject: Any Advice on Instructions Please? Reply with quote
http://propsummit.com/upload/601/br_blaster_kit.jpg
Hi Guys
Just ordered one of these kits ( See above link for photo) so will put a review of it on here once it's to hand and I have had a chance to have a good look at it. To be very fair to the seller he did state clearly that instructions for assembly etc were NOT available so I am wondering if any kind soul on here would be able to give me some advise? The painting is straight forward enough so it's really just the wiring side of things where I'd appreciate some pointers!!
Thanks as always
Paul.
PostPosted: Wed May 06, 2009 5:13 pm    Post subject: Reply with quote
This is one of the resin versions of Sid's most recent blaster build. From what I understand of the Sidkit blasters is they generally arrived already assembled and you had to disassemble them for painting. May be its the same with this version as well.
In any case the assembly isn't quite as complex as it appears at first glance, just make sure you remember where each screw goes. Use a diagram if you have to. Other than that most of the parts fit together fairly logically and its not all that hard to put together. I dismantled my Coyle a few times while giving it a repaint.
oldzey
PostPosted: Thu May 07, 2009 2:40 am    Post subject: Reply with quote
Don't know if this helps, but here are the last set of instructions that Sid had for his All-Metal Worldcon blaster.
Sidkit Worldcon Blaster Instructions:
http://www.box.net/shared/8mdmv7313y
