PKD Magnum
Matsuo
PostPosted: Thu Apr 01, 2010 10:31 pm    Post subject: PKD Magnum Reply with quote
Been a while since I've posted. Figured I'd drop in and share a recent build I did for a buddy of mine.
It ts a Doppelganger PKD Magnum, great kit from Rick as usual.
The build may seem un-remarkable at first but the truth is that this kit came to me already built and painted. It seemed a little worse for wear and the paint was somewhat thick on it obliterating some of the subtle engraving. I had no choice but to completely strip the piece and start over, no small feat in itself.
Also my hatred of glue is legendary so I broke all the bonded joints and replaced them with screws and locator pins.
The grips had a bad offset so I pulled the threaded studs, filled the holes, re drilled and pressed them back in.
The trigger guard was shrunk a bit, I did a bit of fitting and re fitting to make it look right (by my reckoning) and fastened it with screws.
I re wired the LED's and made it so the 'mag' that holds them is held in with a screw.
I drilled and tapped cross pins for the triggers so they would move, I'm still trying to work out a spring loaded mech for them, but theres not a lot of room to work with in there. If for nothing else even if they cant be spring loaded I like to have my triggers float free so they stand less a chance of being broken.
The grips are frosty so short of replacing them theres not a lot I can do.
The colors are worldcon inspired, I wanted it subtle, not too flashy
So here you go... Just so you know I'm not all Pulse Rifles and Galactica blasters. Wink
Thanks for looking hope everyone is well!
Matt
PostPosted: Thu Apr 01, 2010 11:04 pm    Post subject: Re: PKD Magnum Reply with quote
Matsuo wrote:
Matt
A really perfect build mate. Hard to believe that its not steel. You have done a magnificent job and I'm grateful to you for sharing...
Bravo
Regards
MARK
PostPosted: Fri Apr 02, 2010 12:37 am    Post subject: Reply with quote
Matt you are a Master. So how much do you charge to build a PKD? That thing is awesome.
Matsuo
PostPosted: Fri Apr 02, 2010 7:55 am    Post subject: Reply with quote
Thanks!
I buid them so infrequently I never really set a price.
I'll have to think about it.
M
PostPosted: Fri Apr 02, 2010 9:32 am    Post subject: Reply with quote
Matt, that is insane!
Love seeing your work.
Neil.
Nexus6
PostPosted: Fri Apr 02, 2010 9:10 pm    Post subject: Reply with quote
A MASTERFUL job, as usual.
jfuste
PostPosted: Sat Apr 03, 2010 2:20 am    Post subject: Reply with quote
Thinking about sending you my two kits to be mounted and painted so well! Wow!
Great job!
PostPosted: Sat Apr 03, 2010 10:09 am    Post subject: Reply with quote
That's a sweet build, Matt! Shocked
Very very nice. I like it.
K
Mr_Creepy
PostPosted: Sat Apr 03, 2010 10:51 am    Post subject: Reply with quote
Absolutely gorgeous rebuild Matt! Shocked
- Brian (formerly ToothTech)
PostPosted: Sun Apr 04, 2010 7:29 am    Post subject: Reply with quote
Matt, nobody thought for a sec. that you were a one trick pony (Pulse rifle ). Sharp build, clean line and great paint Cool
