Takagi Mod - Custom Gaff "Dandy" Blaster
Talyn
PostPosted: Sat Oct 21, 2017 1:58 pm    Post subject: Takagi Mod - Custom Gaff "Dandy" Blaster Reply with quote
Finally calling this done. Went back and forth on the brass screws on the grips because they are a departure from anything used on the original, but I thought they went well with the pearl. All of the LEDs are just glued on. The piece on the front of the receiver was from the inside of a small faucet filter.
I removed and molded the original grips and then made pearl castings. I filled the entire blaster with resin and filled out the grip frame for the new grips to glue onto. I used the orange tip cap as a barrel extension. Everything was aged with various weathering powders, which is what gives the receiver that slight brown hue.
There are only a few added greeblies here and there, but itís really amazing what can be done with this squirt gun.
RPF: Kylash
PostPosted: Sat Oct 21, 2017 4:58 pm    Post subject: Reply with quote
Thats fantastic, great job. Very Gaff. Cool
How the hell did you get the grips to look like that?
Talyn
PostPosted: Sat Oct 21, 2017 6:58 pm    Post subject: Reply with quote
Thanks, I made molds of the toy grips and cast them with clear resin with pearlEx powder mixed in, which gives the metallic swirls look and leaves some translucency.
RPF: Kylash
rickhoward
PostPosted: Sat Oct 21, 2017 7:36 pm    Post subject: Reply with quote
Fun stuff. Thanks for sharing.
PostPosted: Sun Oct 22, 2017 10:38 am    Post subject: Reply with quote
Fun stuff indeed and those grips look a lot like the real one veekthor got from the Propstore Cool
Talyn
PostPosted: Mon Oct 23, 2017 4:42 pm    Post subject: Reply with quote
Thanks guys. I just figured I should make it a custom blaster since the stamping on the top isnt accurate anyway. If i were to have made Deckard's out of it, that wrong stamping would bug me, so i went this route, which could plausibly have different stamping (and be made in China).
That was partially where I got the idea, if it was almost what Deckard's had, its good enough for me!
RPF: Kylash
veektohr
PostPosted: Mon Oct 23, 2017 7:10 pm    Post subject: Reply with quote
This turned out awesome. That pearl finish is smack on for the test pair!
EJ_Watts
PostPosted: Tue Nov 14, 2017 8:36 pm    Post subject: Reply with quote
Great work! I particularly like the unique look with those great grips. I've been working on a squirtgun mod as well, tell me - were you able to keep the triggers movable, or did the resin seize them up?
Talyn
PostPosted: Thu Dec 07, 2017 4:37 pm    Post subject: Reply with quote
I made them fixed, filling with resin complicated that a bit and it just made it easier.
RPF: Kylash
ogrotesque1
PostPosted: Wed Jan 03, 2018 5:10 pm    Post subject: Reply with quote
Iím digginí this! Nice work, very nice work....
Damion: ogrotesque1
