Voight-Kampff Concept Build
MarsVoyager
PostPosted: Sun Mar 11, 2018 10:38 am    Post subject: Voight-Kampff Concept Build Reply with quote
I've started to build a Voight-Kampff machine (VK). As a conceptual start I've used Lego to give some hints on if I get the size and construction right.
I used LED arrays from Kingbright as input for the size. That was for the red 10 LED array and the green-red 12 LED array.
Compare the work done by @MarcusKirsch here: Voight Kampff Test - UK - german built
Other main references for my machine were the pictures on these forum pages:
And of course the movie... (Blade Runner)
And here a picture comparing my build with one of the deleted scenes from
"Blade Runner (Complete Deleted Scenes/Lost Footage)" on YouTube https://youtu.be/7xBKrz0wdsM
As this is Lego, you can determine the width of my machine. Do you accept the challenge?
No artificial animals were harmed in the production
PostPosted: Mon Mar 12, 2018 1:43 pm    Post subject: Reply with quote
The Lego approach is a new one for me Shocked might be the solution to get the right size
MarsVoyager
PostPosted: Sat Mar 17, 2018 8:45 am    Post subject: Reflection photo comparison Reply with quote
I'm now happy with the size after comparing with this photo.
I also found the original photo useful when finding the height of the VK feet. This height should be half the distance between the base and its reflection.
The reflection was also useful when I placed my thumbs, I found that the thumb tips are aligned with the back edge of the machine.
MarsVoyager
PostPosted: Sun Mar 18, 2018 4:03 pm    Post subject: VK Font Reply with quote
I made a first version of a VK font. You can check it out here:
MarsVoyager VK Font (.zip)
I've only tested the Mac version. Only upper case letters have glyphs. I worked extensively with kerning. What do you think?
PostPosted: Sun Mar 18, 2018 4:04 pm    Post subject: Reply with quote
Love the work you did with the fonts
MarsVoyager
PostPosted: Sat May 05, 2018 12:00 pm    Post subject: Reply with quote
Thank you Joberg.
I played around with fonts a bit more and created a monospace font for the two small screens. This is based on the two YouTube clips posted by Anders Buch:
I couldn't post the text in monospace here (the code tag doesn't do it). So these are images.
The left screen:
GRID PLASMA FLD QUAD SR3
RATE
DRIFT
The red row moves up and down, while the red text "0277 3R9" flashes.
The right screen:
INERTIAL DAMPING NUL G
J66543 M2 T70007 AL 55436
PostPosted: Sun May 06, 2018 9:54 am    Post subject: Reply with quote
Love the screens and the look! Anders did a great job also Wink
MarsVoyager
PostPosted: Tue May 08, 2018 2:41 pm    Post subject: Red and green-red LED arrays, sequence comparison Reply with quote
Some electronics ready, the 10 red and 12 green-red LED arrays.
I made this clip, comparing my sequencing with the movie. It is at 50% speed to last a bit longer, the total length of the movie reference is only 26 seconds.
I think I got the timing right, there is some smoothing between the different clips added. One thing I noted was that the last two red LEDs of the ten are never shown lit.
I haven't found any correlation between the two LED arrays. Any creative ideas on what they measure?
PostPosted: Wed May 09, 2018 6:24 pm    Post subject: Reply with quote
Very well made!! Keep up the great work Cool
MarsVoyager
PostPosted: Thu May 10, 2018 1:45 pm    Post subject: Voice over transcript Reply with quote
Thanks again Joberg, glad you liked it.
I find the Deckard Voice Over interesting. Here is my transcript from the Rachael test in the deleted clip:
I don't remember if it made it to the movie, but it gives some background.
Deckard (Voice Over):
It was always a thrill running a Voight-Kampff on a known human being. All you get is zero-zero-zero.
Just to humor the big shot I ran 62 questions in the Omega series, 28 in the Colman series.
And I was coming to the end of the Cumming cross reference when I got a cold chill down my spine.
I'm not sure if I got the terms "Omega", "Colman" and "Cumming" right...
You wonder what the thrill with a 0-0-0 result is, perhaps you don't expect it during the test.
The following dialogue we know as:
Deckard: She's a replicant, isn't she?
Tyrell: I'm impressed. How many questions does it usually take to spot one?
Deckard: I don't get it Tyrell.
Tyrell: How many questions?
Deckard: Twenty, thirty, cross-referenced.
Tyrell: It took more than a hundred for Rachael, didn't it?
PostPosted: Thu May 10, 2018 6:06 pm    Post subject: Reply with quote
You got those names right. Wink
MarsVoyager
PostPosted: Mon May 21, 2018 4:22 pm    Post subject: Movie machine screens Reply with quote
I'm comparing the screen clips used on the close-up shots (earlier post) with the lower machine used with the actors. This is about the best I can get, but they differ quite a bit:
They don't change much in the three clips (total 16s) during the Leon test.
  • Both smaller screens have a dark background.
  • The left small screen has some increasing animation on it.
  • The right small screen seems static.
  • The larger screen with the eye appear to be in black and white, and it only has slight movement.
I think I will stick with the close-up clips for my lower-version machine.
I also noted, while walking through the scene frame-by-frame, that Holden has his blaster in his hand for a few frames after he has been shot. That was new to me, and I wondered if this was known by the community. I found that Joberg posted that in 2009 here:
Blade Runner White Dragon Cut
PostPosted: Mon May 21, 2018 6:27 pm    Post subject: Reply with quote
Yes, the Holden gun is still in his hand when going through the screen and hitting the table. Wink
