Want to buy: This Contempra internal part
kurtyboy
PostPosted: Sun Dec 18, 2011 6:01 pm    Post subject: Want to buy: This Contempra internal part Reply with quote
Has anyone got a spare one of these? It comes from the inside of the Contempra phone. I acceidentally ruined my one Sad
This is the part as used on Fred's fine Vid-Phon. It has been cut down. Originally there are three 'blocks' with the hole and two rectangular tabs in them and each one has a brass piece clipped in place.
Oh, and it's glossy black plastic originally!
Thanks
PostPosted: Mon Dec 19, 2011 8:00 am    Post subject: Reply with quote
Remember, that same piece can be find in the other "Contempra" the one with the rotary dial instead of the buttons in the hand-set.
Cheaper to buy and it's easy to find...I'll check my stuff to make sure Wink
kurtyboy
PostPosted: Mon Dec 19, 2011 3:10 pm    Post subject: Reply with quote
Goody goody, thank you! I'd rather not have to buy another phone just for that one little piece Confused
PostPosted: Mon Dec 19, 2011 5:42 pm    Post subject: Reply with quote
Ah damn, sorry I can't help you kurty...
How did you ruined that piece, BTW ?
Sad
kurtyboy
PostPosted: Mon Dec 19, 2011 7:11 pm    Post subject: Reply with quote
Cutting it, changing my mind, glueing back together, cutting again, glueing... finding it out of shape and trying to heat it to unwarp it. Ended up warping way out of shape! Laughing
Sad
PostPosted: Tue Dec 20, 2011 3:39 am    Post subject: Reply with quote
Oh my !!!
Poor little piece of plastic... I guess it looks like something out of Frankenstein right now...
Sad
PostPosted: Tue Dec 20, 2011 8:05 am    Post subject: Reply with quote
You'll have to remind me where in the phone you can find the piece (main body or hand-held piece)...also the rotary one is waayyy much cheaper than the button one (Cdn funds: $20).
jameth
PostPosted: Tue Dec 20, 2011 10:24 am    Post subject: Reply with quote
It's in the base. It has several of the little squares with the holes and little metal in each.
I used that part for my customers finished Vidphone. It was already done so I could not open it up so I used the last phone I had.
kurtyboy
PostPosted: Tue Dec 20, 2011 12:18 pm    Post subject: Reply with quote
Yeah, I know. But I don't want another phone, I only want that one detail part so it's not worth paying $30-$40 (including shipping) for it! Laughing
PostPosted: Tue Dec 20, 2011 2:17 pm    Post subject: Reply with quote
Thanks Jameth I'll check in one of my many boxes at home to see if I still have a complete body Wink
PostPosted: Tue Dec 20, 2011 6:49 pm    Post subject: Reply with quote
Alright folks, I'll need some advice here about the way to open that phone...I cannot, for the life of me, see any screws Confused it as if somebody installed rivets or something Evil or Very Mad (the one I have is the Nothern Electric)
The Nothern Bell has only 2 screw to keep the cover in place (if my memory serves me well) and that one was sold a long time ago Crying or Very sad
kurtyboy
PostPosted: Tue Dec 20, 2011 6:58 pm    Post subject: Reply with quote
There are two black plastic tabs in the corners through the square holes. You just press them in and towards the front of the phone with a screwdriver to unclip them while you prize the black cover off, one at a time.
It is a little tricky mind you!
jameth
PostPosted: Tue Dec 20, 2011 7:51 pm    Post subject: Reply with quote
Mine also has a screw under the phone number paper where the receiver sits.
Tom
kurtyboy
PostPosted: Tue Dec 20, 2011 7:58 pm    Post subject: Reply with quote
DOH! That too!
Tom
PostPosted: Wed Dec 21, 2011 8:12 am    Post subject: Reply with quote
The screw under the phone number has been taking care of; I'll try the clips to see how it goes...thanks for the advice
kurtyboy
PostPosted: Wed Dec 21, 2011 3:27 pm    Post subject: Reply with quote
My fingers are crossed Wink
PostPosted: Wed Dec 21, 2011 5:45 pm    Post subject: Reply with quote
It's a negative KB Confused I failed to see any of those bits inside the body of my Contempra...I think that mine is of another model (Nothern Electric 1979). Maybe somebody could confirm is that piece belong to a Nothern Bell and ''younger" (1980-81).
Lemme take a pic and you'll see what I mean.
Later Wink
kurtyboy
PostPosted: Wed Dec 21, 2011 5:56 pm    Post subject: Reply with quote
I too thought it wasn't in my phone because it looks quite different and I didn't see it at first because as far as I remember you have to remove some other part before you get to it. I basically gutted the phone out removing everything that is not used by the keypad or seen!
Later Wink
PostPosted: Wed Dec 21, 2011 7:22 pm    Post subject: Reply with quote
KEYPAD Shocked Exclamation Is it me or someone told me it was inside the main body?...not the hand-held piece.
jameth
PostPosted: Wed Dec 21, 2011 7:25 pm    Post subject: Reply with quote
It's in the base. I think he just meant he took out everything but the keypad out of both.
I took both apart just to be sure.
