kurtyboy Community Member
Posted: Sun Dec 18, 2011 6:01 pm Post subject: Want to buy: This Contempra internal part |
Has anyone got a spare one of these? It comes from the inside of the Contempra phone. I acceidentally ruined my one
This is the part as used on Fred's fine Vid-Phon. It has been cut down. Originally there are three 'blocks' with the hole and two rectangular tabs in them and each one has a brass piece clipped in place.
Oh, and it's glossy black plastic originally!
Thanks |
Posted: Mon Dec 19, 2011 8:00 am Post subject: |
Remember, that same piece can be find in the other "Contempra" the one with the rotary dial instead of the buttons in the hand-set.
Cheaper to buy and it's easy to find...I'll check my stuff to make sure  |
Posted: Mon Dec 19, 2011 3:10 pm Post subject: |
Goody goody, thank you! I'd rather not have to buy another phone just for that one little piece
joberg wrote: | Remember, that same piece can be find in the other "Contempra" the one with the rotary dial instead of the buttons in the hand-set.
Posted: Mon Dec 19, 2011 5:42 pm Post subject: |
Ah damn, sorry I can't help you kurty...
How did you ruined that piece, BTW ?
Posted: Mon Dec 19, 2011 7:11 pm Post subject: |
Cutting it, changing my mind, glueing back together, cutting again, glueing... finding it out of shape and trying to heat it to unwarp it. Ended up warping way out of shape!
SKIN JOB 66 wrote: | Ah damn, sorry I can't help you kurty...
Fred |
Posted: Tue Dec 20, 2011 3:39 am Post subject: |
Oh my !!!
Poor little piece of plastic... I guess it looks like something out of Frankenstein right now...
kurtyboy wrote: | Cutting it, changing my mind, glueing back together, cutting again, glueing... finding it out of shape and trying to heat it to unwarp it. Ended up warping way out of shape!
Fred |
Posted: Tue Dec 20, 2011 8:05 am Post subject: |
You'll have to remind me where in the phone you can find the piece (main body or hand-held piece)...also the rotary one is waayyy much cheaper than the button one (Cdn funds: $20). |
jameth Community Member
Posted: Tue Dec 20, 2011 10:24 am Post subject: |
joberg wrote: | You'll have to remind me where in the phone you can find the piece (main body or hand-held piece)...also the rotary one is waayyy much cheaper than the button one (Cdn funds: $20). |
It's in the base. It has several of the little squares with the holes and little metal in each.
I used that part for my customers finished Vidphone. It was already done so I could not open it up so I used the last phone I had. |
Posted: Tue Dec 20, 2011 12:18 pm Post subject: |
Yeah, I know. But I don't want another phone, I only want that one detail part so it's not worth paying $30-$40 (including shipping) for it!
Posted: Tue Dec 20, 2011 2:17 pm Post subject: |
Thanks Jameth I'll check in one of my many boxes at home to see if I still have a complete body  |
Posted: Tue Dec 20, 2011 6:49 pm Post subject: |
Alright folks, I'll need some advice here about the way to open that phone...I cannot, for the life of me, see any screws it as if somebody installed rivets or something (the one I have is the Nothern Electric)
The Nothern Bell has only 2 screw to keep the cover in place (if my memory serves me well) and that one was sold a long time ago  |
Posted: Tue Dec 20, 2011 6:58 pm Post subject: |
There are two black plastic tabs in the corners through the square holes. You just press them in and towards the front of the phone with a screwdriver to unclip them while you prize the black cover off, one at a time.
It is a little tricky mind you! |
Posted: Tue Dec 20, 2011 7:51 pm Post subject: |
Mine also has a screw under the phone number paper where the receiver sits.
Tom |
Posted: Tue Dec 20, 2011 7:58 pm Post subject: |
DOH! That too!
jameth wrote: | Mine also has a screw under the phone number paper where the receiver sits.
Tom |
Posted: Wed Dec 21, 2011 8:12 am Post subject: |
The screw under the phone number has been taking care of; I'll try the clips to see how it goes...thanks for the advice  |
Posted: Wed Dec 21, 2011 3:27 pm Post subject: |
My fingers are crossed
joberg wrote: | The screw under the phone number has been taking care of; I'll try the clips to see how it goes...thanks for the advice  |
Posted: Wed Dec 21, 2011 5:45 pm Post subject: |
It's a negative KB I failed to see any of those bits inside the body of my Contempra...I think that mine is of another model (Nothern Electric 1979). Maybe somebody could confirm is that piece belong to a Nothern Bell and ''younger" (1980-81).
Lemme take a pic and you'll see what I mean.
Later  |
Posted: Wed Dec 21, 2011 5:56 pm Post subject: |
I too thought it wasn't in my phone because it looks quite different and I didn't see it at first because as far as I remember you have to remove some other part before you get to it. I basically gutted the phone out removing everything that is not used by the keypad or seen!
joberg wrote: | It's a negative KB I failed to see any of those bits inside the body of my Contempra...I think that mine is of another model (Nothern Electric 1979). Maybe somebody could confirm is that piece belong to a Nothern Bell and ''younger" (1980-81).
Later  |
Posted: Wed Dec 21, 2011 7:22 pm Post subject: |
KEYPAD Is it me or someone told me it was inside the main body?...not the hand-held piece. |
Posted: Wed Dec 21, 2011 7:25 pm Post subject: |
joberg wrote: | KEYPAD Is it me or someone told me it was inside the main body?...not the hand-held piece. |
It's in the base. I think he just meant he took out everything but the keypad out of both.
I took both apart just to be sure. |
