Posted: Mon Sep 05, 2016 1:22 pm Post subject: |
| Looking very good so far! |
veektohr Community Member
Posted: Mon Sep 05, 2016 1:33 pm Post subject: |
| Clean up looks like it's gone well! How much drilling & tapping is left? |
Posted: Mon Sep 05, 2016 1:49 pm Post subject: |
| joberg wrote: | | Looking very good so far! |
Thanks
| veektohr wrote: | | Clean up looks like it's gone well! How much drilling & tapping is left? |
I still need to do some on the two handles and most exciting: the barrel...
From experience the barrel is a bit tricky to drill and tap... not something you should do late in the evening being tired etc.... so I'll save it for the weekend...
This kit really is much fun working with, you get to know EVERY inch of this prop, which is very cool  _________________ Monsieur, azonnal kövessen engem bitte
Posted: Mon Sep 05, 2016 2:26 pm Post subject: |
On the small side screws, mark the dill points well, then center punch them, THEN START straight get the hole started THEN turn the barrel slowly and watch out for bending the drill bit until you are now drilling at the angle you need..I do the big screw for the ammo housing first and with it in in the barrel turn it until it is level with the dill table...straight out the side..parallel to the dill table.
Hot Tip.
Posted: Mon Sep 05, 2016 2:37 pm Post subject: |
| racprops wrote: | On the small side screws, mark the dill points well, then center punch them, THEN START straight get the hole started THEN turn the barrel slowly and watch out for bending the drill bit until you are now drilling at the angle you need..I do the big screw for the ammo housing first and with it in in the barrel turn it until it is level with the dill table...straight out the side..parallel to the dill table.
Hot Tip.
Rich |
I would never have thought of that! Brilliant! Thanks, Rich  _________________ Monsieur, azonnal kövessen engem bitte |
Posted: Mon Sep 05, 2016 2:53 pm Post subject: |
It is how I do them.
Posted: Tue Sep 06, 2016 7:55 am Post subject: |
There's a tiny little hole on the receiver.... what's the best way to fill it up?
I can't get the damn solder to stick in the hole... any tricks?
I suspect my solder iron is too weak, it's only 15W...
Any ideas?
Posted: Tue Sep 06, 2016 8:46 am Post subject: |
I use a mini-welding torch...
You need a very hot soldering iron..or soldering gun and some pure flux to clean the metal as you melt in the repair.
Didn't you request some extra metal for these??
You really need to use the same metal to repair that/any part that will remain metal.
On any painted part any body filler like bondo or glassing putty will work great. _________________ I never have enough time to do all I want to do! |
Posted: Tue Sep 06, 2016 9:36 am Post subject: |
Thanks for a really quick reply, Rich!
So if I melt some pewter with a torch...... how do I get it in the hole? Pour it? Or let it drip melt over the hole?
No, I didn't request extra metal, I think that was someone else. I have a lot of pewter (95% tin 4% antimony 1% copper)... think that will do?
| racprops wrote: | I use a mini-welding torch...
On any painted part any body filler like bondo or glassing putty will work great. |
Posted: Tue Sep 06, 2016 9:51 am Post subject: |
You need to heat the main body and melt the metal into it and both the new and old metal needs to melt together.
Can you work around this long enough for me to mail you some filler metal??
I find for a good matching finish you really need repair metal of the same maker and batch.
Other wise there is a good chance it will look different and show.
Posted: Tue Sep 06, 2016 10:39 am Post subject: |
| racprops wrote: | You need to heat the main body and melt the metal into it and both the new and old metal needs to melt together.
Rich |
Ahh! I see... Yes, of course! Just PM me about shipping costs, address etc. I really don't need much extra metal, it's a tiny little hole...
Then I'll practice this technique on some other pewter scraps in the mean time...
Thanks again, Rich! _________________ Monsieur, azonnal kövessen engem bitte |
Posted: Tue Sep 06, 2016 11:42 am Post subject: |
Resend me you mailing address a couple pieces should go into envelope AOK. _________________ I never have enough time to do all I want to do! |
Posted: Thu Sep 08, 2016 9:56 am Post subject: |
Test fitting slotted screw and binding post on side cover... the brass colored binding post looks so amazing! It's almost a shame painting it!
Posted: Thu Sep 08, 2016 10:00 am Post subject: |
Nice, you need to cut two slots near the ribs to make it accurate.
Look at the cast version I included with the kit.
Posted: Thu Sep 08, 2016 10:12 am Post subject: |
| racprops wrote: | Nice, you need to cut two slots near the ribs to make it accurate.
Rich |
Thank you, Rich!
This is why I love this hobby... I've looked at the pictures of this blaster for hours and hours; this is my third build and fourth blaster all together, and I still never noticed that detail!!!!! _________________ Monsieur, azonnal kövessen engem bitte |
Kokanee Community Member
Posted: Thu Sep 08, 2016 10:25 am Post subject: |
| Yes, I've discovered that building one of these blasters is a journey more than a destination... |
Posted: Thu Sep 08, 2016 10:26 am Post subject: |
I know it is insane, it looks like you use a little open end wrench to tighten it. _________________ I never have enough time to do all I want to do! |
Posted: Thu Sep 08, 2016 10:28 am Post subject: |
Go slow you can cut thought the thin shell and it looks crappy then, I cut about 10 of them and lost three... _________________ I never have enough time to do all I want to do! |
Posted: Thu Sep 08, 2016 11:10 am Post subject: |
| Kokanee wrote: | | Yes, I've discovered that building one of these blasters is a journey more than a destination... |
Yes, precisely
| racprops wrote: | | Go slow you can cut thought the thin shell and it looks crappy then, I cut about 10 of them and lost three... |
Good advice! Sounds a bit tricky... Thanks  _________________ Monsieur, azonnal kövessen engem bitte |
Posted: Fri Sep 09, 2016 6:14 am Post subject: |
Looking good Anders: yes, it's all worth it and damn...do I love that slotted screw  |
