Posted: Thu Dec 07, 2017 7:45 am Post subject: |
Good research and mock-up Hellnback and thank you Colin for having re-posted Mark Stetson's pics (as you can see on the last one, the little fins are clearly visible at the bottom of the trench )
The bellows are actually resting on the side of the machine. The one piece vac-form housing is therefore higher than the sides...hence the difference in height that you saw on the blueprint.
Man, that prop is sooo difficult to do right  |
Hellnbak Community Member
Posted: Thu Dec 07, 2017 1:09 pm Post subject: |
Colin,
All good points, but I have to disagree about the arm placement. To me it just doesn't work as showing the angle of the head resting in the trench, seems all wrong for that. And the lines projecting up and to the left would be unnecessary for that, to me they look like an indication of the arm in the raised position. But hey, you know what they say about opinions, and the point is moot anyhow
I've been messing with this thing, and here's how it's looking so far. Quite a mess, to be sure....
but somewhere in there some sort of Voight-Kampff is slowing emerging. I think.
Steve _________________ Politicians are like diapers.....they both need to be changed often, and for the same reason |
Posted: Thu Dec 07, 2017 1:16 pm Post subject: |
| joberg wrote: | Good research and mock-up Hellnback and thank you Colin for having re-posted Mark Stetson's pics (as you can see on the last one, the little fins are clearly visible at the bottom of the trench )
The bellows are actually resting on the side of the machine. The one piece vac-form housing is therefore higher than the sides...hence the difference in height that you saw on the blueprint. |
Thanks, Joberg. Someday a video will emerge showing the actual building process of this beast, and all our questions will be answered. Right?
| joberg wrote: | Man, that prop is sooo difficult to do right  |
Yes, it's very difficult to build something right when nobody knows what right is for this thing  _________________ Politicians are like diapers.....they both need to be changed often, and for the same reason |
Posted: Sat Dec 09, 2017 8:57 am Post subject: |
Had to take some time off from my project, furnace went out, and that's not a good thing to have happen when in Michigan. In December.
But I did make some progress on building some sort of model using the PropShop drawings. Not sure how useful it will be, none of the projected lines lined up, had to made a lot of semi-educated guesses. But this is what I ended up with....
And can someone tell me what this is in the indicated area?
Posted: Sat Dec 09, 2017 9:41 am Post subject: |
Looking good Hellnbak.
I think those lines are the projection of the six vertical fins. Just how far they stick out in plan view.
If that makes sense.
framed Community Member
Posted: Fri Dec 27, 2019 4:42 pm Post subject: |
Hi Hellnbak,
It's been 2 years now since your last post. I am quite interested how far you are now?
Regards,
Ray _________________ always a pleasure |
Posted: Sun Jul 12, 2020 12:44 pm Post subject: |
| framed wrote: | Hi Hellnbak,
Regards,
Ray |
Ray,
Just came across my VK Model while browsing thru my folders. It's been a long time since I played with it, and it prompted me to visit the forum here to see what has been going on. A lot to catch up on, it will take some time.
Hope everyone is doing well and staying safe.
Posted: Sun Jul 12, 2020 12:45 pm Post subject: |
Regards,
Ray |
Ray,
Posted: Sun Jul 12, 2020 12:46 pm Post subject: |
Regards,
Ray |
Ray,
Posted: Sun Jul 12, 2020 12:59 pm Post subject: |
Regards,
Ray |
Ray,
Posted: Sun Jul 12, 2020 1:12 pm Post subject: |
Ray,
Posted: Sun Jul 12, 2020 1:16 pm Post subject: |
Sorry for the multiple posts. Each time I would attempt to post my reply it would give me an error message. So I kept trying. Had no idea that it was actually posting my reply even tho it was telling me that it couldn't because of an error. _________________ Politicians are like diapers.....they both need to be changed often, and for the same reason |
Posted: Sun Jul 12, 2020 1:56 pm Post subject: |
That's right...despite the "error" msg, your first try in the good one  |
Posted: Sun Jul 12, 2020 1:59 pm Post subject: |
Embarrassing though  _________________ Politicians are like diapers.....they both need to be changed often, and for the same reason |
Posted: Sun Jul 12, 2020 2:00 pm Post subject: |
And I'm still getting the dang error message each time. Any ideas on that? _________________ Politicians are like diapers.....they both need to be changed often, and for the same reason |
Posted: Sat Jul 18, 2020 10:08 am Post subject: |
Not embarrassing since it's not your fault Andy will fix it  |
Posted: Thu Jun 24, 2021 8:05 pm Post subject: |
Well, almost another year has passed. thought I would check in to see what's going on here in the forums. Thinking about continuing my VK project, but I have a lot going on right now so I'll have to do what I can when I can.
Hope everybody made it thru all the madness ok _________________ Politicians are like diapers.....they both need to be changed often, and for the same reason |
Posted: Thu Jun 24, 2021 8:15 pm Post subject: |
I see the error msg problem is still around. I got this msg when I attempted to post the above message, but when I checked I found that the message had actually posted ok, just like before.
Well, it's been so long I've forgotten how to post an image here. Here's what the error msg said --
General Error
Failed sending email ::PHP::
DEBUG MODE
Line : 234
File : emailer.php
Any idea what this means?[/img] _________________ Politicians are like diapers.....they both need to be changed often, and for the same reason |
Posted: Fri Jun 25, 2021 9:16 am Post subject: |
Glad to know that the V.K. project is still in the works...despite real life making it difficult, sometime, to work on our favorite props/models.
As for that error msg...I'm afraid I cannot help you there. AFAIC, I can still upload pics without any problems.  |
